Just now, RONOTHAN## said:
Depends. What are you doing when it's at 102C (playing a game, rendering a video, sitting on the desktop doing nothing, etc.), and what CPU do you have in said Omen 15?
Im in the lobby for valorant, i have discord and opera GX open
The CPU is the "ryzen 7 4800h with radeon graphics"
https://linustechtips.com/topic/1618407-cpu-temperature/#findComment-16770782
4 minutes ago, Jepper said:
Is it normal for a around 5 year old omen 15 to have a CPU temp of aorund 102 C°
Is it normal?  Probably not, needs to be cleaned out, dust removed, etc.  Or stop using it on your lap or fluffy pillows.
Can it happen?  Definitely.   Any laptop can be overheated, it's the physics of lots of work vs enclosed space.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1618407-cpu-temperature/#findComment-16770783
1 minute ago, YoungBlade said:
Welcome to the Forums!
That is unlikely to be normal. Most CPUs have a max temperature in the range of 90C to 100C. 102C is likely too hot.
Can you give us the full specs of the system? Or the model number of the Omen 15 so we can look it up?
CPU - ryzen 7 4800h
GPU - 2060
Memory - 16gb (i dont know if i have xmp on or not but ive heard that it increases temp
https://linustechtips.com/topic/1618407-cpu-temperature/#findComment-16770784
I have cleaned itout like 2-3 months ago
I have it on a cooling pad
https://linustechtips.com/topic/1618407-cpu-temperature/#findComment-16770785
20 minutes ago, Jepper said:
CPU - ryzen 7 4800h
GPU - 2060
The TJMax (max temperature considered in spec) for that CPU is actually 105C. So 102C is within spec.
It's hot, but it's a high power draw laptop chip, so as long as AMD says it's within spec, 102C is okay. Not ideal, but not necessarily a problem.
https://linustechtips.com/topic/1618407-cpu-temperature/#findComment-16770797
ok ty for responding
https://linustechtips.com/topic/1618407-cpu-temperature/#findComment-16770806
You might want to replace the thermal paste as if this is indeed this omen https://www.notebookcheck.net/HP-Omen-15-laptop-Review-Strong-AMD-processor-makes-Intel-tremble.512679.0.html
Then yeah this is getting very hot for just valorant and discord. A prime 95 load + furmark for the gpu only got the cpu to 86c in a 20c room. Since it's 4 years old now a repaste would probably not be a bad idea.
It's a very efficient laptop cpu so doesn't make much heat, however it being so hot does mean that most likely there is still dust left or needs a repaste. Which is not abnormal around 3 years is usually when a gaming laptop would not mind a repaste.
https://linustechtips.com/topic/1618407-cpu-temperature/#findComment-16770809
Did you open it to fully clean the interior and repaste the CPU ?
https://linustechtips.com/topic/1618407-cpu-temperature/#findComment-16771237
Running a Ryzen 7 4800H at 102°C is extremely close to the thermal limits (105°C) and can absolutely accelerate long-term degradation.
Temperatures above 100°C can speed up electromigration within the chip, which reduces lifespan and stability over time. Even if it doesnt throttle immediately, its still damaging.
The power delivery (VRM) modules near the CPU can also overheat due to radiant heat and poor airflow, especially in laptops. This reduces efficiency and may cause instability under load or premature component failure.
RAM modules often sit close to the CPU/GPU in laptops, and without direct airflow, they can reach temperatures where error rates increase. Long-term high temperatures can degrade RAM, or can lead to BSOD under heavy load
Motherboard PCBA when continuously exposed to these temps > can cause long-term damage to the motherboard layers, BGA solder joints, and even lead to warping or micro-fractures.
What are your load temperatures for SSD and RAM? What's your temperature difference between the GPU and the GPU hotspot? VRAM temp? If the difference is more than 15°C, the thermal paste is already dead or the heatsink has the wrong pressure; ideally, you should be below 10°C
If a particular comment or answer solved your problem, please mark it as the solution. If you found something helpful or useful, consider giving it a like as well, it helps others too. 😉
https://linustechtips.com/topic/1618407-cpu-temperature/#findComment-16771259
Commercial pads don't work much because the fans have almost zero static pressure in them! The only effect they have is that they lift the laptop off the table, and the fans can suck air better, nothing more. If you don't want to tinker with your own pad, then buy one that works, like IETs 500/600 or similar. They are more expensive, but worth it because they really work😉
https://linustechtips.com/topic/1618407-cpu-temperature/#findComment-16771268
What are your load temperatures for SSD and RAM? What's your temperature difference between the GPU and the GPU hotspot? VRAM temp? If the difference is more than 15°C, the thermal paste is already dead or the heatsink has the wrong pressure; ideally, you should be below 10°C. Your idle temperatures?
https://linustechtips.com/topic/1618407-cpu-temperature/#findComment-16771273
