Hello.
My  computer froze now  power cycles, and a red cpu light is on my motherboard.
My specs are z490 arours master motherboard
1080 ti msi
Intel i9 10900kf
2 16gb sticks of ram
M.2 and hard drive
Xion 1000 watt power supply.
I was thinking its my power supply.
Please help if you can
Thanks!!
https://linustechtips.com/topic/1617733-need-help-please-pc/
11 minutes ago, Funnycat1403 said:
Hello.
1080 ti msi
Intel i9 10900kf
M.2 and hard drive
Thanks!!
It could definitely be your power supply.  If its the XION XON-1000P14F you are using then its old and quite terrible.
Try to reset the CMOS.
https://linustechtips.com/topic/1617733-need-help-please-pc/#findComment-16766289
