I currently have a intake in the front and two exhaust at the top and rear. Will adding an intake at the bottom and another exhaust at the top make mu case run cooler? Also are nzxt cases only compatable with nzxt fans or will other brands fit?
Adding more fans will only decrease temps by a tiny bit, and no they don't have to be NZXT fans its just the size that matters, you can have 2 140mm fans in the top and 120mm fans everywhere else. In my 410 I have 3 noiseblocker black silent pros, a silverstone air perpetrator and 2 corsair AF120's.
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
https://linustechtips.com/topic/161764-nzxt-410-cooling/#findComment-2153701
by tiny bit, how much? Like 1-2c?
https://linustechtips.com/topic/161764-nzxt-410-cooling/#findComment-2154383
yeah 1-2c pretty much nothing
https://linustechtips.com/topic/161764-nzxt-410-cooling/#findComment-2154659
