Help me pick a GPU
Solved by jaslion,
6 minutes ago, youssef10112 said:Do you reckon it's best to wait then a few months for price drops or newer models?
Unlikely at the moment. We are in the first third of this generation of cards so unlikely new gpu's come out. At best some slightly different versions like a nvidia super. Intel is the only one still expectes to release new cards in your budget this year.
If you have to buy now get the 7800xt its the best buy. Yes worse fsr but well it has better base performance
