Desperately need help
I've got a msi b550 tomahawk max wifi mobo
Ryzen 9 5900x cpu
Crucial 500gb(for os)m.2 ssd
Wd black 4tb(for bulk)m.2 ssd
MSI Gaming GeForce RTX 5060 8GB OC gpu
Corsair vengeance 32 gb 3200mhz ram
(Need to know anything else feel free to ask)
Pretty much the entire booting process I've been fighting this pc(probably bc its my first time and I didnt know fully what to expect)
My bios update was a pain to install or figure out how to install.
However I ran into a really big problem.
I was installing windows and it wanted me to install the wifi driver so I used command prompt to open explorer to allow me to access and install the amd chipset software installer and download what is supposed to be my drivers package.(i had just the wifi driver on the flash drive but it wouldn't show any files on the flash drive just folders thats why I used command prompt. But at the same time the wifi driver setup window was super confusing bc it seemed like nothing was working in it. So i just downloaded the amd chipset software installer.) It needed to restart after the install and we'll it wont fully boot up all the way after that. How do I fix this and finally get this build finished so I can begin enjoying my pc I've worked so hard to get.
https://linustechtips.com/topic/1617146-help/
Ryzen 9 5900x cpu
Okay, so basically it sounds to me like the windows installer failed?
In that case, create a new windows installation media, and this time instead of trying to install drivers in the installation process, press shift+f10 and type "start ms-ch:localonly" to skip the wifi requirement during install.
Then sort the drivers once you’ve made it to desktop.
I might be experienced, but I'm human and I do make mistakes. Trust but Verify! I edit my messages after sending them alot, please refresh before posting your reply. Please try to be clear and specific, you'll get a better answer. Please remember to mark solutions once you have the information you need. Expand this signature for common PC building advice, a short bio and a list of my components.
Common build advice:
1) Buy the cheapest (well reviewed) motherboard that has the features you need. Paying more typically only gets you features you won’t use. 2) only get as much RAM as you need, getting more won’t (typically) make your PC faster. 3) While I recommend getting an NVMe drive, you don’t need to splurge for an expensive drive with DRam cache, DRamless drives are fine for gamers. 4) paying for looks is fine, just don’t break the bank. 5) Tower coolers are usually good enough, unless you go top tier Intel or plan on OCing. 6) OCing is a dead meme, you probably shouldn’t bother. 7) "Bottlenecks" rarely matter and "Future-proofing" is a myth. 8) AIOs don't noticeably improve performance past 240mm and don't improve at all past 360mm. 9) RTFM.
Useful Websites:
https://www.productchart.com - helps compare monitors, https://uk.pcpartpicker.com - makes designing a PC easier.
Bio:
He/Him - I'm a PhD student working in the fields of reinforcement learning and traffic control. PCs are one of my hobbies and I've built many PCs and performed upgrades on a few laptops (for myself, friends and family). My personal computers include 4 windows (10/11) machines and a TrueNAS server (and I'm looking to move to dual booting Linux Mint on my main machine in future). Aside from computers, I also dabble in modding/homebrew retro consoles, support Southampton FC, and enjoy Scuba Diving and Skiing.
Fun Facts
1) When I was 3 years old my favourite toy was a scientific calculator. 2) My father is a British Champion ploughman in the Vintage Hydraulic Class. 3) On Speedrun.com, I'm the world record holder for the Dream Bobsleigh event on Mario & Sonic at the Olympic Winter Games 2010.
My Favourite Games: World of Tanks, Runescape, Subnautica, Metroid (Fusion and Dread), Spyro: Year of the Dragon (Original and Reignited Trilogy), Crash Bash, Mario Kart Wii, Balatro
My Computers: Primary: My main gaming rig - https://uk.pcpartpicker.com/user/will0hlep/saved/NByp3C Second: Hosts Discord bots as well as a Minecraft and Ark server, and also serves as a reinforcement learning sand box - https://uk.pcpartpicker.com/user/will0hlep/saved/cc9K7P NAS: TrueNAS Scale NAS hosting SMB shares, DDNS updater, pi-hole, and a Jellyfin server - https://uk.pcpartpicker.com/user/will0hlep/saved/m37w3C Foldatron: My folding@home and BOINC rig (partially donated to me by Folding Team Leader GOTSpectrum) - Mobile: Mini-ITX gaming rig for when I'm away from home -
https://linustechtips.com/topic/1617146-help/#findComment-16762602
Ryzen 9 5900x cpu
Just reinstall windows. The media might be alright. But you need the correct driver for chipset, wlan etc.
Simply download the lan drivers and run. And dont use cmd for this. No need to run anything else from MSI. Only if you have trouble with audio, then use the audio driver as well:
https://www.msi.com/Motherboard/MAG-B550-TOMAHAWK-MAX-WIFI/support#driver
Before installing anything else, install chipset drivers: https://www.amd.com/en/support/downloads/drivers.html/chipsets/am4/b550.html
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
https://linustechtips.com/topic/1617146-help/#findComment-16762607
I have not tried it with a new windows install media but I have tried to have windows retry the install but it never finishes it restarts like a boot loop. Is there a way I can remove the drivers it installed to see if it will get me to where I was before?
https://linustechtips.com/topic/1617146-help/#findComment-16762681
How do I install the drivers before windows? Or just remove the ones i installed so i can get back to where i was. I've tried having it retry installing windows but it never completes installing it, it always restarts like a boot loop.
https://linustechtips.com/topic/1617146-help/#findComment-16762682
If you have tried reinstalling windows then you have alreadly removed the drivers.
It seems like you might have a different issue.
Where is your PC getting stuck in the process?
Useful Websites:
Bio:
Fun Facts
https://linustechtips.com/topic/1617146-help/#findComment-16762683
Just now, Lilbuddah said:
Black screen 87%
Sorry I dont have more information i can't remember what else it says on that screen but it gets to 87% then restarts the pc and install process. I'm at work right now but I can try it again when I get off to get a fresh memory of it
https://linustechtips.com/topic/1617146-help/#findComment-16762732
