pc guide builds Need help for First time PC build
Solved by strange13930,
4 hours ago, Tempidkbadatnames said:Hi, wont an r5 7600x be better than the intel one? Including the fan cost the 7600x comes to about the same as the 12400f.
yes but going with the 7600x is $70(including the new motherboard) more bringing your budget down for a gpu, I made one change to the cpu in the original list to the 12600kf because it's a smaller price gap than I thought it was(i'm more well versed with amd and not as much intel) the 12600kf will be a little worse for gaming it's better for productivity like video editing.https://pcpartpicker.com/list/BBBLXR
