Help: CPU and GPU low usage
20 minutes ago, Tykennan said:Hey guys, I just set up my pc and booted up doom dark ages and everything is running okay at max settings but my gpu usage and cpu usage were like 60-70% and 3% respectively. I was getting around 60-70 fps with but I’m a little concerned the usages were so low. I also loaded up Minecraft with the new vibrant visuals and it looks like I couldn’t get any higher than 120fps with near identical usage percentages. I get crazy high fps in the menus of both games as expected, I’ve disabled vsync, enabled expo, enabled resizable bar, changed my power settings, updated my bios, removed any frame caps updated gpu drivers. What am I missing here.
my specs are:
ryzen 9 9950x3d
rtx 5090 astral oc
g.skill 2x24 8000
T705 2tb
ROG x870e-e mobo
EXPO might be a problem at 8000 as you are not running in 1:1 with the infinity fabric, this is why we always recommend 6000Mhz CL30.
The 9950X3D might also need some adjustments or core parking depending on your OS so that you are running on the X3D cores.
