Hello everyone,
I'm having an issue with one of the USB.
It appears to be corrupt and prompts to format the USB before using it.
There are important files in it and I tried recovering the file before formatting it, and that didn't work out too well.
I decided that maybe after I formatted the USB, I might be able to recover some of the files that was erased; however, I can't seem to format the USB.
I tried the following:
1. Right clicking and do a quick and non quick format -- no progress
2. formatting through disk management -- no progress, couldn't even delete volume.
3. using 3rd party programs to delete the partition -- no progress.
What I noticed is that when I try to format the USB, it seems that the Capacity is wrong. It only shows 8.00 MB and I'm not sure if this might be the problem.
Can someone help? I'm trying to do this for my sister as the USB have quite important files for school.
Also, I'm not sure if I'm posting this under the right section. :/
https://linustechtips.com/topic/161536-usb-corrupt-need-help/
Try rufus to format it, if that doesnt work the usb may be dead
Case: NZXT Phantom PSU: EVGA G2 650w Motherboard: Asus Z97-Pro (Wifi-AC) CPU: 4690K @4.2ghz/1.2V Cooler: Noctua NH-D15 Ram: Kingston HyperX FURY 16GB 1866mhz GPU: Gigabyte G1 GTX970 Storage: (2x) WD Caviar Blue 1TB, Crucial MX100 256GB SSD, Samsung 840 SSD Wifi: TP Link WDN4800
Donkeys are love, Donkeys are life.                    "No answer means no problem!" - Luke 2015
https://linustechtips.com/topic/161536-usb-corrupt-need-help/#findComment-2150202
I had the same issue and came across this post
http://geekswithblogs.net/ilich/archive/2013/04/26/recovering-unallocated-space-of-a-usb-flash-drive.aspx
It helped a lot and got my drive up and running very quickly, hopefully it helps you as well.
CPU: i7 5820K 4.0GHz @1.15V | MOBO: Asus X99 Sabertooth | GPU: Gigabyte Windforce GTX 980Ti, LTT Orange | CASE: NZXT H440 Black 2015 | COOLER: Noctua NH-D15S w/ LTT Fans | RAM: 32GB Patriot 3000MHz | STORAGE: 512GB Samsung 950 Pro, 960GB Sandisk Ultra II 3 x 8TB Seagate HDD's | PSU: 750W Seasonic X series, black / orange cablemod cables| Monitors: 3x Asus VX24AH's | AUDIO OUT: Microlab SOLO 8C, Sennheiser HD 650's, Audio engine D1 Amp / DAC | AUDIO IN: Blue Snowball | Keyboard: CM Storm QuickFire TK MX Green | Mouse: Logitech G900 Proteus Spectrum + RSI Extended Mouse Pad | PCPP Linkhttp://nz.pcpartpicker.com/list/hPjFd6
https://linustechtips.com/topic/161536-usb-corrupt-need-help/#findComment-2150207
Thanks for your effort guys...
It didn't really work. I think if I were to use that usb again, it would require erasing the flash chip. At that point, I don't think any of the files would be recoverable.
https://linustechtips.com/topic/161536-usb-corrupt-need-help/#findComment-2157663
