41 minutes ago, testcy said:
I was thinking about ARCTIC FREEZER 36 for about the same price, but wouldn't this still be overkill?
probably overkill but it just means that you dont need to upgrade your cooler for the forseeable future and quieter operation ontop of that
oh and get the phantom spirit, freezer 36 is just worse outright in terms of performance
https://linustechtips.com/topic/1614458-cooler/#findComment-16744624
10 hours ago, testcy said:
What cooler could I use that is not overkill for a 65W AMD Ryzen such as 9600X that does not come with one?
Thermalright Assassin X 120 Refined SE 66.17 CFM CPU Cooler or
https://linustechtips.com/topic/1614458-cooler/#findComment-16744720
21 hours ago, KidKid said:
I don't shop from Amazon and I can't find Thermalright elsewhere.
Some other options I have around the price of Thermalright are:
ARMAGGEDDON BLIZZARD3 ARGB
COOLER MASTER HYPER 411 NANO ARGB
SILVERSTONE ARGON AR12 RGB
ENDORFY FERA 5
Are any of these worth considering?
https://linustechtips.com/topic/1614458-cooler/#findComment-16745085
ENDORFY FERA 5
They all kinda suck tbh especially the ancient cooler master
Maybe the frozn a620 or ag620?
https://linustechtips.com/topic/1614458-cooler/#findComment-16745161
ENDORFY FERA 5
The COOLER MASTER HYPER 411 NANO ARGB will work perfectly fine, being able to cool up to 180W. The Silverstone should work too. Realistically, any aftermarket cooler should be able to cool 65W.
https://linustechtips.com/topic/1614458-cooler/#findComment-16745197
3 hours ago, testcy said:
Are you talking about DEEPCOOL AG620? I can't find ID-COOLING FROZN A620.
yes but if you cant find any of thesei guess whatever cheap 15-20$ 4 heatpipe like the se 214 xt will suffice aswell just that youll probably have to upgrade it if you go for a more power hungry cpu in the future and itll also run a tad louder
https://linustechtips.com/topic/1614458-cooler/#findComment-16745306
  • 4 weeks later...
I asked a couple cooler manufactures about 65W and 105W processors and one went as far as to suggest liquid cooling. How realistic is that?
https://linustechtips.com/topic/1614458-cooler/#findComment-16760621
It should be liquid nitrogen/ immersion cooling, or at least custom water cooling.
Jokes aside, If you want the best cooling while not delving into extreme stuffs, 360 / 420 AIO that has thicker radiator & fans than standard.
Overkill for your CPU? Very.
For comparison, I once used an old Hyper 212 for 5900x for heavy gaming.
I've long changed it to a 280mm AIO because it was noisy AF, the CPU still works fine today.
https://gamersnexus.net/coolers/best-air-coolers-cpus-2023-thermals-noise-value
https://gamersnexus.net/megacharts/cpu-coolers
Refresh before you reply
https://linustechtips.com/topic/1614458-cooler/#findComment-16760701
They just want your money. 65W, even 105W can be cooled fine by an air cooler.
https://linustechtips.com/topic/1614458-cooler/#findComment-16760723
Out of all of those, maybe the arctic. But in my eyes all of those coolers listed are junk. Why cant you buy it from Amazon?
AMD R9 9900X | Thermalright FW Pro Black, 3x TL-B12E | Asus Strix X670E -F | 64GB G.Skill 6000C26
Zotac 4070 Ti Trinity OC | WD SN850, SN850X, 2x SN770 | Seasonic Vertex GX-1000 | ProArt PA602
Adcom GFP-345, Adcom GFA-555, S.M.S.L D1+PS100, Cerwin-Vega! CLSC-15, Monster HDP-1800
https://linustechtips.com/topic/1614458-cooler/#findComment-16760809
