I have 2 ennermax fans with temp sensors on them one is on the bottom of the case as an intake and one on the back as a exhaust I also have a fan on the front top as an intake as my 760 windforce is huge and cuts the bottom off from the top of the case so what will be the bast placement fir the sensors to have the exhaust run off the cpu and the bottom intake run off the gpu
Also it's there a way to turn the sensors into a pwm cable or something similar
"if nothing is impossible, try slamming a revolving door....." - unknown
my new rig bob https://uk.pcpartpicker.com/b/sGRG3C#cx710255
Kumaresh - "Judging whether something is alive by it's capability to live is one of the most idiotic arguments I've ever seen." - jan 2017
https://linustechtips.com/topic/161429-temp-sensor-location-or-mod/
so that whole PWM this is a no go then oh well
Only way I know is to make a circuit board up or buy something like this http://www.svc.com/pwmx.html
You would have to disable the temp sensor but that would depend on if the sensor read hot or cold as 0v resistance.
Probably cheaper to buy new fans
the sensor would prob read cold a 0 to stop the fan there has to be a way but there only case fans so i will proberbly leave it
Just put somewhere where the temp won't change much
i have the sensors by the gpu for the bottom intake fan so when the gpu ramps up the fan does and by the cpu cooler so when the cpu ramps up the exhaust fan on the back ramps up, TBF there really quite
