Budget (including currency): 90.000RSD (roughly $900 USD)
Country: Serbia
Games, programs or workloads that it will be used for: A sort of baseline I was starting from is the Baldur's Gate 3 Recommended system requirements, then go up wherever applicable. That will probably the most intensive game I'll play for a while, and beyond that it'll mostly be movies and shows online.
Other details : PCPartPicker list: https://pcpartpicker.com/list/PYs3kf
It should be noted that I'm getting a second hand GPU and CPU, and in case the CPU comes with a stock cooler, I'll probably use it and not buy a new one. In terms of peripherals, because I am renting an apartment, no space for additional furniture, and the location of the router, meaning no ethernet...it's not great. I'll be using a 1366 x 768 HD Ready, 200Hz TV, have a Wifi adapter, and most probably use rechargable wireless mouse and keyboard.
Honestly, in terms of peripherals I am willing to take the bare minimum, I am mostly looking for feedback if I made a mistake in the actual PC components. Any suggestion for the sake of future upgrades are appreciated, but I'll most probably sell/give this PC and make a new one in the future.
https://linustechtips.com/topic/1613987-first-build-looking-for-feedback/
Country: Serbia
Its an okay budget build.
I would skip that DeepCool PSU.. I know you are on a budget but its on the E:Tier on the updated PSU Tierlist. Basically, avoid at all cost.
I would look at an MSI A650BN instead.
Country: Serbia
Pretty decent but if that GPU is $500, you're way overpaying.
Thanks, I didn't know this tier list was something I should take into account. After cross referencing the tier list and what I could find on the store, I'll be switching over to the NZXT C750 Bronze 750W
Retail it's roughly $300, but the second hand one I found is $140
So why does it show over $500 in the part list?
Country: Serbia
I made some changes like cheaper ram, a motherboard with wifi, and a better cpu https://pcpartpicker.com/list/cjsdYd
Wow! Looks much better than the original build, for even less $! Good job!
