Will this power 2 780 Ti's 24/7?
xD6N
my specs are listed in my signiture. will this PSU manage to operate 2 780 Ti's?
http://www.ebuyer.com/631165-corsair-rm-series-rm1000-80-plus-gold-1000w-atx-eps-fully-modular-power-cp-9020062-uk
 My PC: CPU: i7 4770K @ 4.2 Ghz MoBo: ASUS Z97-ATX SLI RAM: 8GB (2x4) 2400Mhz GPU: Palit Jetstream 780 TI Memory:1TB Seagate + 120Gb Kingston SSD  PSU: Corsair RM 850W Gold Monitor iiyama 27" 144hz Monitor CPU Cooler Corsair H100i
yes, it should be fine, but do you mean 24/7 full load?
Intel 3570k 3,4@4,5 1,12v Scythe Mugen 3 gigabyte 770     MSi z77a GD55    corsair vengeance 8 gb  corsair CX600M Bitfenix Outlaw 4 casefans
Yes.
well not 24/7 but quite a lot of use
it should be more than enough, even 750 watt should be enough
thanks for the help, but ill deafintly need the headroom :)
the mobo probably wont allow 4 way sli so, no, no you wont :P
Proud Member of the Glorious PC Master Race
thats true haha, but extra power is always nice to have.
for the RM series i would actually agree, but the only thing you gain would be more silent running at low loads.
Your current 850W psu will be enough for 780ti sli.
Your current RM850 will easily power them both.
Specs are on my profile page
 Teach a man to fish and he ends up sticking a screw driver in a turned on power supply seeing if it still works.        #KilledMyWifeWithABomb            Resolution is just a number
