The removable microphone on my tritton pro + headset isn't working
Can anyone think of why it might not be working
If I can't fix it, can anyone find a good microphone for under £20 for a temporary replacement
Thanks
CPUIntel 4670k  Motherboard - Gigabyte GA-Z87X-D3H  RAMKingston HyperX 8GB  GPU - EVGA 780  Case - Fractal Design Define R4    Storage - 2TB WD Black, Samsung 840 Evo 128GB     PSU - Corsair RM650  Display -  Benq XL2430T and Acer S235HL  Cooling - CM Hyper 212 Evo  Keyboard - Corsair K95  Mouse - Razer Deathadder  Sound - Sennheiser HD 558                                 Mic - Blue Snowball  Phone- OnePlus One  Tablet - Nvidia Shield
https://linustechtips.com/topic/161327-microphone-not-working/
You could just buy another on eBay http://www.ebay.co.uk/itm/Tritton-Replacement-microphone-for-the-Pro-and-720-/201051723812?pt=UK_Headsets&hash=item2ecf9dd824
but another option I would recommend that is cheap are the Microsoft LX3000 wear it round your neck its a pretty darn good microphone/headset for the price.
https://linustechtips.com/topic/161327-microphone-not-working/#findComment-2147602
There is a zalman clip on mic that is good enough as a temporary replacement and I found this with better review.
Do you mean this ? Both of your links went to the neewer one
Zalman
https://linustechtips.com/topic/161327-microphone-not-working/#findComment-2147611
Doesn't matter, i accidental muted it on the in line volume control
Derp
https://linustechtips.com/topic/161327-microphone-not-working/#findComment-2147613
............................................________
..............?.....__.........................................:`.........../
............./__.(.....“~-,_..............................,:`........../
.........../(_....”~,_........“~,_....................,:`........_/
..........{.._$;_......”=,_.......“-,_.......,.-~-,},.~”;/....}
...........((.....*~_.......”=-._......“;,,./`..../”............../
...,,,___.\`~,......“~.,....................`.....}............../
............(....`=-,,.......`........................(......;_,,-”
.............\`~.*-,.....................................|,./.....\,__
,,_..........}.>-._\...................................|..............`=~-,
.....`=~-,_\_......`\,.................................\
................................`:,,...........................`\..............__
........................................_\..........._,-%.......`\
...................................,<`.._|_,-&``................`\
Twitter | Steam |
https://linustechtips.com/topic/161327-microphone-not-working/#findComment-2147626
