Problem with rx 7600xt
Go to solution Solved by PDifolco,
2 hours ago, lorenzino said:
hey guys, i am having trouble with my amd card.
I can play whatever game i want but not cs2. for example, hell let loose is not a problem to run, i can play for 3 hours and it's fine. I have about 30 second in-game in cs2 before it crashes to a black screen and my display says no signal.
i have already whiped my entire system and reset it ( i was on a nvidia gpu before so i thought it was a conflict of gpu drivers) but it seems that it doesn^t change anything.
Hardware should not be a problem since the card is basically new.
i don't know what should try next...
Try lowering max clock in afterburner
https://linustechtips.com/topic/1612406-problem-with-rx-7600xt/
is ReBar on? chipset updated? BIOS updated?
current PC:
PC configs I used before:
https://linustechtips.com/topic/1612406-problem-with-rx-7600xt/#findComment-16730848
https://linustechtips.com/topic/1612406-problem-with-rx-7600xt/#findComment-16730882
 is that going to impact perdormance ? Or not so much
depends on how much you lower it
https://linustechtips.com/topic/1612406-problem-with-rx-7600xt/#findComment-16730966
Better having 200FPS with no issue than 215 and crashing every 10 min, isn't it ? 😛
https://linustechtips.com/topic/1612406-problem-with-rx-7600xt/#findComment-16731111
10 hours ago, lorenzino said:
Yes rebar is on and everything updated
Try rebar off, you never know, sometimes it can fix the issues, kind of like dark magic, but PC.
current PC:
https://linustechtips.com/topic/1612406-problem-with-rx-7600xt/#findComment-16731357
lowering the clock worked so well, i'm getting around 120fps which less than before BUT my system is stable now no crash + it's a lot more quiet. thanks for the advice !
https://linustechtips.com/topic/1612406-problem-with-rx-7600xt/#findComment-16731603
Great !
Idk why but I also have graphix drivers crashes in some games, and lowering max clock always fix it, for an acceptable around 10% performance loss
https://linustechtips.com/topic/1612406-problem-with-rx-7600xt/#findComment-16731988
