Hey - need some help please.
Ive just spent some money on a mid-tier components (poor father of 3 here).
I have bought this board - https://www.asus.com/uk/motherboards-components/motherboards/tuf-gaming/tuf-gaming-b550m-plus-wifi-ii/
I want a new case - and saw this - https://www.amazon.co.uk/FOIFKIN-M1-Case-Pre-Installed-Mid-Tower/dp/B0DXQG3MDK/ref=sr_1_2_sspa?crid=ILSTG6CO8IIZ&dib=eyJ2IjoiMSJ9.GLL74bSyWIzkGsT4pFthMDYbP1KJC_ynpOvE9N2M6XdObTOZhVCLdlE8BQZP6fA-nIj97Lo3tdXxEtDRin34HptqpEksYuicZbXPEHZVqZEHmJ5uN3jbeg1njFhtyZIQRZk0V2P74Upvdtow1hk3wwz-_PTJdMpXw4MtDRzO7_5r2EWjWkAfSHeeRlXiByg-tzu7JEYpPY8CzCIgoxIJrYZClS-6T43YRKUPjy6Kmkk.iab0GY2HU4ZKpGkMdJfYtUQyW4PUhOsHUi2o53mF7u0&dib_tag=se&keywords=M1+PC+Case+-+Wood+Walnut+front&qid=1746087198&sprefix=m1+pc+case+-+wood+walnut+front%2Caps%2C71&sr=8-2-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&psc=1
This fits my budget, and honestly does what it needs, however!
Im not sure if the fans in this case will work with the board? I always struggle to understand ARGB etc. And these seem to be called Aura RGB?
I just need to know if these fans will just work if I plug them in, not arsed about RGB to be honest, as long as they spin lol.
With it only have 2 headers, and 4 fans on the case - is there anything I can buy, like a hub to power them, make them work if not?
Rob.
https://linustechtips.com/topic/1610598-not-sure-about-argb-help/
Rob.
The fans will be daisy chained so you're fine ^^
Rob.
Looks like  a Fractal North clone/ripoff
I'd be wary of noname cheap boards, rather go for a reputable brand budget case, with good reviews, like Montech, Phanteks, Lian Li, Deepcool, Antec
Not even really more expensive :
https://uk.pcpartpicker.com/products/compare/QnD7YJ,KKytt6,2MwmP6,77vD4D/
Anyway any case fans will work with any board, cheap fans may be Molex powered, directly to the PSU
Hi buddy,
PC RGB can be a but of a pain in the arse but in my experience it comes down to NOT wanting to have a million different RGB software control utilities on your PC at once.
From the looks of things, your Mobo has 2 x 12v 4 Pin RGB headers and 1 x 3 pin 5v aRGB header.
Ignore the 4 pin headers as you will likely not use them as the bulk of RGB fans, cases, water blocks and so forth use the 3 pin standard now. If I'm being honest, I'm not sure what uses the 4 pin standard and nothing in my ridiculous selection of flishy flashy PCs uses them. I am assuming the case fans are indeed 3pin 5v.
With regards to how many you can plumb in on a single header, that comes down to how many amps all the devices use. I think 3A is what a single header can handle.
If you want a splitter (powered or unpowered) I have used the following without any issues:
https://www.amazon.co.uk/Argb-CTRICALVER-Ports-ARGB-Splitter/dp/B099DJM2GQ/ref=asc_df_B099DJM2GQ?mcid=d2920dbfeeeb351fbd1f9d8fdb6c8c32&tag=googshopuk-21&linkCode=df0&hvadid=710715439671&hvpos=&hvnetw=g&hvrand=9028011726829597366&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9046885&hvtargid=pla-1423628154854&psc=1&gad_source=1
https://www.amazon.co.uk/QTMMC-ARGB-Splitter-Cable-Addressable/dp/B0DP7J3WS7/ref=sr_1_6?crid=1ILKRKBIPM8BE&dib=eyJ2IjoiMSJ9.dHBTVtwVYnfwyV7jmCIffgCZDpqk6PlMgUUSZZmAO7VzmYU6nfOINqhVU6PPrwxxcwFeBdfKyqOx8YaoxoLIpiCXgJOZxhKqL73YHgCDevifBHqThl-8HKuACzslmIFdHCZks-29x9ZHktvbDdO6VjflVtrGkdcidUceQO35lNN5rjZD2r2tmLiDG9X0MlmcxjGdNsNab6KLidw0Xfltb0VKVbvsGIL7dDVb0JICT6A.x7oys7pAHa2vnno3gfKi_LPBLvJUu2IHtk54gdc4W7g&dib_tag=se&keywords=rgb+splitter+3+pin+5+way&qid=1746095464&sprefix=rgb+splitter+3+pin+5+way%2Caps%2C93&sr=8-6
As @Why_Me suggested, if the case fans are daisy-cahainable for both PWM and RGB you might not need a big splitter, but with only a single 3pin aRGB header on the board, its not a bad addition to make sure everything lights up as it should.
With regards to the RGB control software, my advice is to try and limit it to 1. While Corsair, Lian-Li and almost every other company will try and railroad you into installing their software to control their rgb hardware, your Mobo's control software is usually the best option and normally manages to detect and control everything including RAM.
C
Living Room PC - Lian-Li O11 XL Evo - MSI X870 Tomahawk Mobo - AMD 9800X3D - 32GB DDR5 Ram - RTX 4090 - 2TB Samsung 990Pro NVMe - Antec 1200w PSU - Dual Custom Loop Cooling - GPU cooled with EK Quantum Surface S240 + EK Quantum Surface P360M X-Flow Rads - CPU cooled with EK Quantum Surface X360M Rad
Bedroom PC - Hyte Y60 - Intel Core i5 13600k - MSI Pro-A Wifi Z790 Mobo DDR5 - 32GB Ram - RTX 5070ti - 1TB Samsung 990Pro NVMe - Corsair HX1200i PSU - CPU + GPU cooled with Hyte Y60 Corner Distro Plate - EK Coolstream S120 + EK Quantum Surface S360 + EK Quantum Surface X240M
Extension PC - Lian Li o11 Dynamic - Intel Core i9 9900k - MSI Meg Ace Z390 Mobo - 16GB Ram - RTX 3080ti - 256GB Samsung NVMe - Corsair AX850 PSU - CPU + GPU cooled with dual EKWB 360 Rads + G1 side EKWB distro plate.
Office PC - Thermaltake Tower 100 - Intel Core i7 8086K - Gbyte Z390 I Aorus Pro Wifi Mobo - 16GB Ram - iGPU - 256GB Samsung NVMe - EVGA B5 850W PSU - CPU cooled with dual EK Quantum Surface P120M Rads + Barrow 3-in-1 Block, Res & Pump.
Spare - Corsair 250D - Intel Core i7 8700k - Gbyte Z390 I Aorus Pro Wifi Mobo - 16GB Ram - GTX 980ti - 256GB Samsung NVMe - BeQuiet P11 750 PSU - CPU cooled with EK Coolstream S240 + S120 Rads + EK Pump / Res Combo
Annex - Corsair 280X - Intel Core i7 4790k - Asrock H97M ITX Mobo  - 16GB Ram - EVGA GTX 1080ti - Corsair SFXL600 PSU - CPU + GPU cooled with triple EK Coolstream S240s + EK Pump / Res Combo
NAS PC - Fractal Node 804 - Intel Core i7 3770k - Asus P8Z77-M Mobo - 16GB Ram - MSI GTX 1660 Ventus - Corsair AX850 PSU - Unraid 21TB Storage Server
Living Room AV Setup 5.1.4 - Nvidia Shield - Yamaha RX-A6A - 2 x B&W CM9s2 - 2 x Monitor Audio FX Silvers - 4 x B&W CCM665s - B&W CMCs2 - SVS SB13 Ultra - LG OLED65C1
Extension AV Setup - Sonos ARC + Sub (Gen 3) - LG OLED65C6V + Sonos Amp - 5 x Monitor Audio C265s
Bedroom AV Setup - Yamaha WXC-50 - 2 x B&W CM1s - Rel Quake - LG OLED42C2.
