I've recently upgraded from a 3070ti to a 5080 but now I'm getting constant crashing. Putting any load on the GPU will crash the system. Since upgrading even windows and my BIOS is super sluggish. If I leave the system running for about a minute my screens will go black, with the system still on. Going back to my old GPU or even using integrated graphics resolves all these issues. My specs:
  • i9-10850k
  • Gigabyte Z490 UD AC Motherboard
  • Corsair RM1000x 1000W
  • 32gb corsair vengeance RAM
What I've tried:
  • Flashed my bios to the latest version
  • Updating drivers to latest
  • Rolling drivers back to 572.16 (meant to be more stable)
  • Using DDU before new driver installs
  • Fresh windows reinstall
One thing I have found is forcing the PCIe lane to run at gen 2 fixes these issues (but obviously runs much slower).
I'm out of ideas at this point. Any help would be much appreciated. Thanks
https://linustechtips.com/topic/1608784-5080-running-super-slow/
Is this the newer version with native 3.1 support or the older one?
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
This is the new version with 3.1. Buy the Corsair RM1000x 1000W ATX 3.1 Power Supply Cybenetics Gold Certified -... ( CP-9020271-AU ) online - PBTech.co.nz
  • 2 months later...
Hi there! I have the same issue with a configuration that's almost identical.
  • i9-10900k
  • Coolermaster 750w gold
  • Palit 5070
Everything is fine without the GPU, but with the 5070, the BIOS is sluggish and goes blank at any time. So, we can rule out Windows because I lose the signal even in BIOS.
Did you find a solution to this problem? Do you know what's happening?
Maybe there's some kind of incompatibility between the Z490 motherboard and the 5070?
