CPU not running as it should.
By
ProRe1icXD
in Troubleshooting
in Troubleshooting
Solved by Sawa Takahashi,
Maybe a driver problem. You may need to reinstall Windows to fix it.
As a test, you can run a Linux USB live stick and check the task manager to see how many cores are displayed.
Good luck !
popularlion ·
Posted in Troubleshooting3 -
CallMe_David ·
FancyPants101 ·
Posted in Troubleshooting1 -
BoBo6107 ·
R_public ·
Posted in Networking14 -
apoyusiken ·
Posted in PC Gaming2
