So in my Bitfenix prodigy case I have 4 fans attached to a NZXT Sentry 2 fan controller and I know its a cheap item but this isnt the problem.
I have a 140mm fan in the rear of the case and its attached to a 4to3 pin cable so that I could plug it into my fan controller but the only problem is that I have is the fan now makes a low but annoying noise such as a (buzzzz) or (brrrr) and this never happened before when I connected the fan straight to the PSU and the fan controller works fine too.
Any help on what and why it might be doing this?
"Life is like a box of RAM, you never know which you need"
https://linustechtips.com/topic/160749-cable-adapter-noise/
It's probably the fan that has issues running at low RPM
You can replace the fan, or run it a bit faster
https://linustechtips.com/topic/160749-cable-adapter-noise/#findComment-2139947
