Microsoft remote dekstop mouse problem
Solved by GuiltySpark_,
4 minutes ago, Hunlight said:PArsec is free?
Yes. For a basic single monitor setup which is all you need to stream a game from a PC, there are no fees. Properly supports streaming 3D applications which RDP does not.
4 minutes ago, Hunlight said:how does it work I install it on pc turn on, then on my laptop and connect
Install the client on both PC's and follow the steps to configure them. On one PC, open the client and connect to the other PC.
