Megekko is currently highly overpricing amd gpu's to absurd degrees so I'd really say wait on this.
Else well hefty white build tax. Can absolutly save money on the cooler, board and ram.
What will this pc be used for as a 7900x is a bit of a middle child cpu :p.
https://linustechtips.com/topic/1606419-help-needed/#findComment-16689341
Stupid prices on some of these, don't buy them overpriced.
Consider something like this. Performs the same whilst saving you a lot of money:
PCPartPicker Part List
CPU: AMD Ryzen 7 9700X 3.8 GHz 8-Core Processor  (€358.59 @ Paradigit)
CPU Cooler: ARCTIC Freezer 36 A-RGB CPU Cooler  (€43.87 @ Amazon Netherlands)
Motherboard: ASRock B850M Pro RS WiFi Micro ATX AM5 Motherboard  (€177.00 @ Azerty)
Memory: G.Skill Trident Z5 RGB 32 GB (2 x 16 GB) DDR5-6000 CL36 Memory  (€108.90 @ Alternate)
Storage: Western Digital Black SN770 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (€119.99 @ Amazon Netherlands)
Video Card: XFX Swift Radeon RX 9070 XT 16 GB Video Card  (€869.00 @ Azerty)
Case: Thermaltake Versa H16 ARGB MicroATX Mini Tower Case  (€68.55 @ Amazon Netherlands)
Power Supply: Gigabyte UD-GM PG5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (€121.59 @ Amazon Netherlands)
Total: €1867.49
Generated by PCPartPicker 2025-03-24 10:37 CET+0100
MAIN: Ryzen 7 5800X3D - Kraken X62 Rev 2 - STRIX X470-I - 3600MHz 32GB Kingston Fury - 250GB 970 Evo boot - 2x 500GB 860 Evo - 1TB P3 - 4TB HDD - RX6800 - Antec HCG Platinum - Manta - Silent Wings Pro 4's enjoyer
SetupZowie XL2740 27.0" 240hz - Roccat Burt Pro OG Corsair K70 browns - PC38X - Mackie CR5X's Mackie CR8S-XBT
Current build on PCPartPicker
HTPC: Ryzen 7 2700X - BeQuiet! Shadow Rock 3 - STRIX X570-F - 3200MHz 32GB Corsair Dominator - 250GB Exceria boot - 500GB SN730 - 1TB Sandisk 3D - 4TB HDD - Limited Edition Vega 64 - Corsair RM750x 80+ Gold - North - Alphacool Apex Stealth Metal - BeQuiet! Light Wings
SetupHisense 55E7NQ - Hisense HS205G
HTPC on PCPartPicker
https://linustechtips.com/topic/1606419-help-needed/#findComment-16689381
3 hours ago, Qa7sto said:
I want to build my second pc, but I'm afraid of clearance issues between RAM and the cooler?
can you check with me?
you can see the build in the attachment
Thanks
get a psu with a 10 year warranty like the xpg core reactor ii and get rid of that trash 6000c36 get some 6000c30/32
https://linustechtips.com/topic/1606419-help-needed/#findComment-16689431
