Building first PC
Solved by strange13930,
4 minutes ago, DiceHG said:Budget (including currency): 5000-6500R$
Country: Brazil
Games, programs or workloads that it will be used for: Elden ring, Red Dead Redemption 2, CS2
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): Upgrading from an old pc that i bought (i5-4460, GTX 1060 3GB, 8GB ram (2x4GB ddr3), 1 TB HDD and 500w psu)
After research, i came up with this setup:
looks good, but for ram try and find a kit with 6000MHz speeds and cl30. if your case has a spot to mount the HDD you could use it as extra storage.
