Do any of you know of a good PCI-E fan? I don't plan to buy one, I just wanted to know if it's being done in the mainstream PC building market.
This is all I found: http://www.amazon.com/Vantec-SP-FC70-BL-Spectrum-System-Adjustable/dp/B000233ZMU/ref=sr_1_1?ie=UTF8&qid=1401660077&sr=8-1&keywords=pci-e+fan
https://linustechtips.com/topic/160472-pci-e-fan/
I never even knew anything like that existed.  :o
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
https://linustechtips.com/topic/160472-pci-e-fan/#findComment-2136466
I know Lian Li made a dual slot, dual 120mm fan thingy.
http://fareastgizmos.com/computing/lian_li_double_fan_ducting_system.php
    CPU: 3930k  @ stock                                  RAM: 32GB RipjawsZ @ 2133Mhz       Cooling: Custom Loop
MOBO: AsRock x79 Extreme9                      SSD: 240GB Vertex 3 (OS)                     Case: HAF XB                     LG 34um95 + Ergotron MX Arm Mount - Dual Review
  GPUs: Gigabyte GTX 670 SLI                     HDD: 1TB WD Black                                PSU: Corsair AX 860                               Beyerdynamic - Custom One Pro Review
https://linustechtips.com/topic/160472-pci-e-fan/#findComment-2136485
i7 2600K @ 4.7GHz/ASUS P8Z68-V Pro/Corsair Vengeance LP 2x4GB @ 1600MHz/EVGA GTX 670 FTW SIG 2/Cooler Master HAF-X
http://www.speedtest.net/my-result/3591491194
https://linustechtips.com/topic/160472-pci-e-fan/#findComment-2136638
