Hello good people ! im about to upgrade my i7 9700k to a amd 78003dx and im getting  a new build with the arctic 360m liquid cooler im not sure which case to go for was thinking about the Antec AX90 my gpu is rtx 3070 gigabyte oc
would love to know your opinion about the case
thank you ! have a good day
https://linustechtips.com/topic/1604403-new-build-help/
goat -> goat
overkill for 7800x3D, but it's your money
so you want case recommendations?
what aesthetic? similar to Antec AX90? (mesh front, RGB, glass side, black)
current PC:
PC configs I used before:
https://linustechtips.com/topic/1604403-new-build-help/#findComment-16675601
2 minutes ago, podkall said:
goat -> goat
doesnt have to be similar i just want a case with a good airflow/dust filters thats easy to clean
https://linustechtips.com/topic/1604403-new-build-help/#findComment-16675605
I'm not really sure which cases are easier to clean, or have more tidy filters, but here:
Montech AIR 1000 PREMIUM
Montech AIR 903 MAX
Fractal Design Pop Air
Corsair 4000D Airflow
Fractal Design Focus 2
Fractal Design Focus 2 RGB
Lian Li LANCOOL 216 RGB
be quiet! Pure Base 500DX
Fractal Design Pop Air RGB
Lian Li Lancool 207
These are pretty good cases, using US pcpartpicker parts for ~100$ or less.
current PC:
https://linustechtips.com/topic/1604403-new-build-help/#findComment-16675618
