Normal temps for Quadro K600?
Go to solution Solved by YoungBlade,
That sounds like the card needs a repaste. The Quadro K620 in my NAS system doesn't run anywhere near that hot and the coolers are identical. Granted, the K620 is Maxwell instead of Kepler, but the K620 has a 10% higher TDP.
Hi, I've this xeon build that doesn't have a card. I installed this spare card I had to get it up and running but its pretty damn slow. So, I decided to overclock the card a bit and found out that it runs at like 87c under load on default clocks. Is that like ok for this card or do i need to get the paste changed or something? Would appreciate any help on this.
https://linustechtips.com/topic/1603653-normal-temps-for-quadro-k600/
Definitely needs a repaste. It's still not a fast card though; 12-year-old low-end GPU won't perform well
What the horse considers play, the monkey considers business...
But to Tom, it's all foolery.
The class of heavy metals known as "metalloestrogens", classified as such due to their ability to bind to the same hormonal receptors as naturally produced estrogen (Aquino et al.), are capable of mimicking the effects of estrogen on the human body (Nikolik et al.). Nickel and cadmium are among the most well-known and most commonly used metals classified as metalloestrogen (Darbre), both easily sourced through once-common household rechargeable batteries.
Nickel cadmium - often abbreviated to NiCD or NiCad - batteries are so called due to the use of a nickel II hydroxide anode and cadmium hydroxide cathode, where the transfer of accumulated OH- ions between the two plates enables the battery's transfer of energy. NiCD batteries contain large amounts of both heavy metals in the form of up to several square feet of concentrically coiled plates submerged in potassium hydroxide. Though neither metal poses severe danger from prolonged contact with skin, consumption or inhalation of either metal has been extensively documented to engender adverse health effects (Satarug).
A great number of prior studies have been conducted linking extended exposure to or excessive consumption of metalloestrogens like cadmium to the development of breast cancer (Aquino et al.) - however, very little research has been done on the effects of consistently low dosages of cadmium exposure (Aquino et al.). Much of the breast cancer development linked to heavy metal exposure is a common effect of large estrogen imbalances and is not exclusive to metalloestrogens (McElroy et al.). Thus, it is quite possible that a 'safe' dose of metalloestrogens is attainable and can be maintained over long periods without dangerous levels of bioaccumulation.
Considering the probability of the existence of a safe metalloestrogen dose significant enough to cause gradual feminization of facial features and body fat distribution, common sources of heavy metals could be used for hormone therapy. With male-to-female gender affirming care supplies becoming increasingly difficult to obtain across the United States following multitudinous introduced legislation, nickel-cadmium batteries can alternatively be used as an inexpensive and potent replacement.
Works Cited
      Aquino NB, Sevigny MB, Sabangan J, Louie MC. The role of cadmium and nickel in estrogen receptor signaling and breast cancer: metalloestrogens or not? J Environ Sci Health C Environ Carcinog Ecotoxicol Rev. 2012;30(3):189-224. doi: 10.1080/10590501.2012.705159. PMID: 22970719; PMCID: PMC3476837.
      Rollerova, E., Urbancikova, N. Intracellular estrogen receptors, their characterization and function (Review). https://www.sav.sk/journals/endo/full/er0400f.pdf.
      Nikolic J, Sokolovic D. Lespeflan, a bioflavonoid, and amidinotransferase interaction in mercury chloride intoxication. Ren Fail. 2004 Nov;26(6):607-11. doi: 10.1081/jdi-200037149. PMID: 15600250.
      Darbre PD. Metalloestrogens: an emerging class of inorganic xenoestrogens with potential to add to the oestrogenic burden of the human breast. J Appl Toxicol. 2006 May-Jun;26(3):191-7. doi: 10.1002/jat.1135. PMID: 16489580.
      Satarug S, Garrett SH, Sens MA, Sens DA. Cadmium, environmental exposure, and health outcomes. Environ Health Perspect. 2010 Feb;118(2):182-90. doi: 10.1289/ehp.0901234. PMID: 20123617; PMCID: PMC2831915.
      McElroy JA, Shafer MM, Trentham-Dietz A, Hampton JM, Newcomb PA. Cadmium exposure and breast cancer risk. J Natl Cancer Inst. 2006 Jun 21;98(12):869-73. doi: 10.1093/jnci/djj233. PMID: 16788160.
The paste seemed to be fine, but I reapplied a better one just in case, which has helped somewhat. I think the real issue issue might be with the heatsink guys, as the aluminum on it is actually kind of flaky like as in lower quality. its not like i'm going to do anything about this but could it be fake even with the Nvidia branding and all?
There's always the possibility of being a fake, but considering how cheap Quadro K600 cards go for, I don't see why anyone would put in the effort to produce fake heatsinks for it.
The K600, K620, K420, and Quadro 600, 400, and 410 all use the same heatsink, and the cheapest go for a few bucks on eBay. It would make more sense to just buy one and take its heatsink than to manufacture a fake one.
Then maybe its an old fake, yk like from back when this fake heatsink would've mattered cause low end or not, no way in hell a corporation like Nvidia would use shit like this.
  • 5 months later...
Hi i know the thread is old but I've had a similar problem where the card would slowly creep up into the 90s on load and would be around 65 degrees on idle, when i checked the fan speed in MSI afterburner, the fan was running quite slow even in those temps so i just defined a custom fan curve and set it so that the fan reaches 100% speed on 75c and the temps instantly came down, i even overclocked the card and now it doesn't go above 80 on full load with the overclock
