Arctic freezer 36
Solved by Hinjima,
12 minutes ago, Writer1976 said:I'm planning to get arctic freezer 36 and I know that it has 2 fans but how do they connect to motherboard? If I understand right I don't need optional cpu fan header to plug the second fan. Am I right?
Correct. I checked the Arctic Freezer 36's manual and the fans come with an extra header for the 2nd fan so you don't need two fan headers on the motherboard. One fan plugs into the other fan
