I'm building a professional workstation for serious freelance cad/fea with some AI compute hosting in the mix and I'm having a hell of a time getting Windows 10 or 11 to install and remain stable at all.
My build:
CPU - TR Pro 7975wx
Motherboard - Asus WRX90 Sage SE
RAM - Kingston DDR5 5600 256 GB (KF556R28RBE2K8-256)
GPU - NVIDIA RTX 6000 ADA
Storage - 2x 4tb Samsung 990 pro nvme ssds, 2x 18TB exos HDDs
PSU - EVGA 1600W T2 Supernova (Corsair AX1600i also used for testing)
What I've done so far:
  1. Verified that all bios settings for windows 11 are in place (TPM enabled, CSM disabled, secure boot enabled, and the bios itself is on the latest version). Additionally, I made sure to say yes to the tpm reset prompt on first boot.
  2. The GPU has passed extensive stress testing on both furmark and aida 64 on another machine.
  3. Changing psus to the test psu confirmed to work on another machine (the corsair mentioned above) did not change any system behavior or resolve any problems.
  4. The RAM was tested with the memtest bootable usb and passed 4 runs of tests 0 through 13 with no errors at rated EXPO.
  5. The motherboard was suspected to be faulty and returned when it kept generating a phantom drive that would always show as the last drive on the windows installer drive search list and would always have a 0 byte capacity. Also, on boot to either windows 10 or 11, the operating system consistently fails to boot or if successful often encounters "whea_uncorrectable_error" BSODs. I replaced the return with another board of the same model and the system continues to have exactly the same problems, so it's probably not the mobo.
  6. Removing all but the target boot ssd for initial windows install always fails in exactly the same way regardless of the individual ssd or slot used. My SSDs and HDDs also run fine on other systems.
This seems to leave only my cpu as a culprit - are there any diagnostic tools i can run (preferably bootable usb only) to diagnose exactly what is going on here before I try to make a return (still within my amazon return window). Is there anything else I'm missing here?
Current PC:
    • CPU
      AMD Ryzen 9 9950X3D
    • Motherboard
      MSI MEG X870E Godlike
    • RAM
      G.Skill Trident Z5 Neo 24GBx2 DDR5-8000 CL40-48-48-128 1.40v (F5-8000J4048G24GX2-TZ5N)
    • GPU
      Aorus Xtreme Waterforce RTX 3090 TI
    • Case
      Corsair 7000D Airflow
    • Storage
      (All NVME SSDs) 1 X Samsung 990 Pro (4TB), 2 x 2TB WD Black sn850, Sabrent Rocket 4TB
    • PSU
      Corsair AX1600i, Fully Modular, 80+ Titanium
    • Display(s)
      Alienware AW3423DW, Alienware AW3225QF
    • Cooling
      Arctic Liquid Freezer ii 420, Built in 360mm gpu rad, 7 x 140mm Noctua NF-A14's (4 used as full case fan set, 3 used to upgrade cpu rad fans), 4 x 120mm Noctua NF-F12's (3 used to upgrade gpu rad stock fans, 1 used to fill last remaining case fan slot)
    • Keyboard
      Custom Keychron Q6 Pro
    • Mouse
      Asus Rog Spatha X
    • Sound
      Senheiser Momentum 4
    • Operating System
      Windows 11 Pro
That motherboard has IPMI capabilities, the 0 byte drive is a virtual drive created by the IPMI which allows you to remotely mount a disk image and reinstall an os. Simply ignore it.
As for the BSODs try disabling EXPO.
In pursuit of knowledge and mistakes.
Please quote or @ me if you want me to be notified. Mark replies as answers if they solved your problem.
Folding at Home BOINC
Enabling or disabling expo makes no difference. Memory errors would definitely have shown in the memtest runs with OS instability this bad. Good to know about the ipmi controller!
Current PC:
    • CPU
      AMD Ryzen 9 9950X3D
    • Motherboard
    • RAM
    • GPU
    • Case
    • Storage
    • PSU
    • Display(s)
    • Cooling
    • Keyboard
    • Mouse
      Asus Rog Spatha X
    • Sound
    • Operating System
      Windows 11 Pro
