I’m building a new PC inside the NZXT H6 Flow and have three 120 fans that are daisy chained up front, a 240 AIO up top, a F240 panel fan on bottom and one fan in the back. In total I will need 4 3-pin RGB headers and I only have two with one being for my CPU Cooler. My question is do I buy a couple 2 to 1 splitters or is there a controller that has 3 pin inserts, all I can find is 4? Do I buy 3 pin to 4 pin adapters, with the 3 pin being 5v and 4 being 12 will that cause issues? They are all NZXT fans.
https://linustechtips.com/topic/1602528-argb-pin-connectors/
you can buy a power hub that can do like 10. but if your only doing like 4 fans a splitters would probably be fine too.
4pin is rgb 12v and 3pin is argb 5v they dont mix
Edited by thrasher_565
https://linustechtips.com/topic/1602528-argb-pin-connectors/#findComment-16663012
