7600X temps
Solved by podkall,
1 hour ago, Darklone_star said:No it’s not.
I’ve got a Crosair 4000D, just 2 fans at the front and 1 in the back for now until I get some more
83C is quite cool, believe it or not,
once you get comfortable, you could try PBO, not sure if it might increase temps along with performance, if I remember correctly sometimes it helps with temps somehow, but that could be also after undervolt+PBO
