Building First Gaming PC
https://uk.pcpartpicker.com/list/DbRD74
9700x + 7800xt + 32gb 6000c30
Cpu wise the 9700x is 202£ and should have similar perf to the above video though if valorant doesnt benifit from the extra cores here is the cheaper 9600x at 142£
Gpu wise 7800xt is pretty meh value and used 6950xt are faster for 400-450£ though best value is the 6800xt if you can find em around 350£ or lower as it performs the same as the 7800xt
As for the rest of the parts i cut costs on the case with a similar aesthetic since the pop mini is 90£
went for rgb 6000c30 rams cause id assume youd probably want some extra bling if you prefer the pop air and besides they look best on the hdv anyways since ita a 2dimmer and no empty slots with the extra benifit of being able to push well over 9000 ddr5 though youlll probably be expecting 8400 at most with a good 9700x while faster than 6400 is gonna be a pain to get running
Psu has a 10 year warranty so cant really go wrong with that unless you want a white psu but then itd look like crap cause of the bad colour mixing white cables going to a black board
