Does this build work?
2 hours ago, iHope said:What do you mean? That I can get a cheaper CPU and I'll be fine because I have the 5090 ?
something like that, some apps can utilize CUDA cores in Nvidia graphics cards,
streaming/recording software can use NVENC encoder, which is on the Nvidia GPU, to do 90% of the recording/streaming work.
And, as far as I can see, one of the x3D chips is cheaper than all of the 16 core chips:
with the 9800x3D potentially being cheaper, if it wasn't such a high demand CPU, and was in stock:
- Unless you're not from US and from other country that may have it in stock anyway.
2 hours ago, iHope said:So is the Air cooling I stated above good enough ? (Corsair A115 Twin Tower CPU Cooler)
Dual tower can work, sure.
2 hours ago, iHope said:Unfortunately no, this is the list of manufacturers they have for air-cooling - List.
Corsair, BeQuiet and Noctua have dual towers.
2 hours ago, iHope said:Think I'll stick with the one I stated above, I don't mind paying a bit extra for it.
That works I suppose
X870 AORUS ELITE WIFI7 has 16 phases, so that's more than enough
