recommendations for pc components
Go to solution Solved by TatamiMatt,
4 minutes ago, jsan22 said:
Any recommended gaming motherboards that will work well with the Ryzen 5 7600x and GIGABYTE GeForce RTX 3060 + PSU
anything B650, most are pretty good, if youre unsure choose a few in your price range available to you and send in here and we can advise
this is a handy website for it, choose your country and itll give recommendations based on the cheapest price for each model thats available to you from a handful of sources
https://uk.pcpartpicker.com/
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
Case Fans: Fractal Prisma (120 x6, 140 x3) + 2x40mm fans
Any AM5 motherboard that isn't an A series chipset will work just fine. B650/B850 generally being the cheapest. I see even B850 boards as low as ~$120 USD on Newegg.
Builder/Enthusiast/Overclocker since 2012 with a focus on SFF/ITX since 2014.
$120 is nuts, absolute cheapest board ive seen here is about $145 equivalent for mATX (UK)
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
This website will be beneficial. Thanks, dude
The asrock B850 pro rs is 135€ here which is a STEAL for a good am5 board so yeah don't spend much.
Also op gaming motherboards don't exist. They don't do ANYTHING for helping games it's pure marketing.
Ah i know, id never go for anything beyond what i need in a motherboard, i have a B650 tomahawk rn myself, but i have a good portion of the USBs filled at various points in time and 3 NVMes currently so worth it to have the slightly nicer board but wouldnt pay anything more than that for a motherboard
Is that the white ATX one? If so, £175 here, which is €210 or $215
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
