first build ever help pls
Go to solution Solved by venomtail,
Are my eyes deceiving me and 7900XTX is out of stock for the first time? Crazy. 9070/XT delays and disappointing 50 release and threat of tariffs really has everyone buying the old stuff now. I've put a placeholder $960 for what the 7900XTX should be going for when it's back in stock soon:
PCPartPicker Part List
CPU: AMD Ryzen 7 ac9800X3D 4.7 GHz 8-Core Processor  ($582.99 @ Amazon)
CPU Cooler: Thermalright Peerless Assassin 120 SE V3 70.84 CFM CPU Cooler  ($35.90 @ Amazon)
Motherboard: ASRock B850M Pro RS WiFi Micro ATX AM5 Motherboard  ($159.99 @ Amazon)
Memory: Silicon Power XPOWER Zenith Gaming 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($79.99 @ Newegg Sellers)
Storage: Patriot P400 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($65.98 @ Amazon)
Video Card: Sapphire NITRO+ Radeon RX 7900 XTX 24 GB Video Card  ($960.00)
Case: G.Skill LT1 MicroATX Mini Tower Case  ($69.98 @ Amazon)
Power Supply: Gigabyte UD1000GM PG5 (rev. 2.0) 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  ($139.99 @ Amazon)
Case Fan: Thermalright TL-C12C X5 66.17 CFM 120 mm Fans 5-Pack  ($19.48 @ Amazon)
Total: $2114.30
Generated by PCPartPicker 2025-02-07 10:40 EST-0500
Budget (including currency): 2400 usd
Country: Usa
Games, programs or workloads that it will be used for: mostly games usually simulation games and 4x grand strategy games
Other details so i have peripherals already so im good on that and i already have an idea of what cpu and gpu i want which is the Radeon 7900 xtx or xt im not entirely sure and the Ryzen 7 9800 x3d everything else is in the air and if anyone wants to recommend on the cpu and gpu im open to better choices im only gonna do one monitor at 1080p right now but will more than likely upgrade to 2 or 3 1440p monitors in the future and also im grabbing all of this from micro center if that helps also will not even entertain the idea of water cooling cause i think its just way to much extra and extra work
https://linustechtips.com/topic/1600573-first-build-ever-help-pls/
Country: Usa
I'd go with a 4080, the NVidia software is nice for sim gaming, and you have the budget for the additional $200 over a 7900XTX
5080 is vaporhardware as of now, and isn't really that faster than 4080 anyway
CPU: AMD Ryzen 7 9800X3D 4.7 GHz 8-Core Processor  ($577.67 @ Amazon)
CPU Cooler: Thermalright Peerless Assassin 120 SE 66.17 CFM CPU Cooler  ($34.90 @ Amazon)
Motherboard: Gigabyte B650 GAMING X AX V2 ATX AM5 Motherboard  ($189.00 @ Amazon)
Memory: G.Skill Trident Z 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($109.99 @ Newegg)
Storage: Western Digital WD_Black SN850X 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($139.00 @ iBUYPOWER)
Video Card: Asus TUF GAMING OC GeForce RTX 4080 SUPER 16 GB Video Card  ($1099.99 @ Walmart)
Case: Fractal Design North ATX Mid Tower Case  ($139.99 @ B&H)
Power Supply: Thermaltake Toughpower GF3 TT Premium 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($89.99 @ Amazon)
Total: $2380.53
Generated by PCPartPicker 2025-02-07 09:30 EST-0500
Smt like @PDifolco suggested is a strong suggestion
What I made is mostly an aesthetic all white build as well
https://pcpartpicker.com/list/rRycGJ
A more hybrid build of mine and the one from @PDifolco would be smt like this
https://pcpartpicker.com/list/kLnQcx
I edit my posts for so if you saw a typo.... no you didn't, you are just crazy
Total: $2380.53
is western digital actually a good drive cause i have heard not horrible but not great things
Above recommendations are solid. If you're shopping at Micro Center I'd wait until the 9800X3D is restocked, as they'll sell it to you for $479 instead of the up-charged reseller prices you see online. You'll also get a discount for bundling CPU, Mobo, and RAM. Sometimes a discount for bundling the graphics card as well. Always check the "Sold by Amazon" price for parts you want to buy, as Micro Center will typically price-match them.
EDIT: Also I have used Micro Center's in-house brand NVME drives, Inland, and they have been great for the price. Though you aren't strapped for cash so maybe that doesn't matter. The Inland Performance Plus is a good value NVME drive.
GAMING PC "Ol' Bessie":
Ryzen 7 7800X3D | Radeon RX 9070 XT | Gigabyte B650M AORUS Elite AX | G.Skill Flare X5 6000MT/s CL36 16GBx2 | 5TB of SSD POWER | EVGA SuperNOVA 850W GT | Noctua NH-U14S | Fractal Design Pop! Mini AirCachyOS
Kind Of A Home Lab "Bay":
Ryzen 9 5900XT | Intel ARC A310 | ASUS PRIME B550-PLUS | T-FORCE 3200MT/s 16GBx2 + Corsair 3200MT/s 32GBx2 = 96GB!!! WOW!! | 2TB boot SSD + 8TBx6 HDD RaidZ2 | EVGA SuperNOVA 650W G2 | Phanteks Enthoo Pro M | Ubuntu 24.04 LTS
The Laptop:
Framework Laptop 13 | Intel i5-1340p | G.Skill Ripjaws 3200MT/s 16GBx2 | Solidigm P44 Pro 2TB | CachyOS
my micro center currently isnt out of stock cause i was looking at the 7800 but its way to much but the 9800 is 20 bucks more and its better as far as i understand so i was like why not get an am5 modern cpu for 20 more than the best bang for your buck gaming cpu and ill have to check out the inland and see if i like it cause if its good for a lower price that means i could possibly put it somewhere else
Total: $2114.30
MAIN: Ryzen 7 5800X3D - Kraken X62 Rev 2 - STRIX X470-I - 3600MHz 32GB Kingston Fury - 250GB 970 Evo boot - 2x 500GB 860 Evo - 1TB P3 - 4TB HDD - RX6800 - Antec HCG Platinum - Manta - Silent Wings Pro 4's enjoyer
SetupZowie XL2740 27.0" 240hz - Roccat Burt Pro OG Corsair K70 browns - PC38X - Mackie CR5X's Mackie CR8S-XBT
Current build on PCPartPicker
HTPC: Ryzen 7 2700X - BeQuiet! Shadow Rock 3 - STRIX X570-F - 3200MHz 32GB Corsair Dominator - 250GB Exceria boot - 500GB SN730 - 1TB Sandisk 3D - 4TB HDD - Limited Edition Vega 64 - Corsair RM750x 80+ Gold - North - Alphacool Apex Stealth Metal - BeQuiet! Light Wings
SetupHisense 55E7NQ - Hisense HS205G
HTPC on PCPartPicker
