A friend been wanting a sitstand desk, but he wants it to have 4 legs, for stability.
From all the sitstand available here so far Idasen is the most stable, atleast when it's about back and forth motion, sideways, not so.
And the 4 legged sitstand base available are either affordable chinesium with very weak motor... like so damn slow even without a tabletop, or a very expensive chinesium which motor is standard (from the pics, it's methink basically what idea in my mind below, just better designed look wise etc, and less janky DIY in cabling or stuff)
After looking at the system used for a lot of sitstand table available here, which is what looks to me like RJ45 connector for connection between the control hub to the motor/controller I thought .... what if he buys two of the same brand & model sitstand base, then use an RJ45 splitter to connect 1 control hub to both bases control system.
My logic says it should send signal for raise/lower at the same time to both control system, and therefore raising/lowering both base at the same time.
then use the two base for the same tabletop.
Dumb idea ?
Refresh before you reply
https://linustechtips.com/topic/1600302-dumb-or-it-will-work/
Any links?
If it's really that simple of a system, your idea should work.
Ryzen 7 5700X3D (CO -30) - AX370-Gaming 5 - 2x16GB @3600C18 - EVGA RTX 3070 8G XC3
[PBO2] CO -25/-25/-30/-30/-30/-30/-30/-30
[BIOS] Vsoc 1.1 / DRAM XMP
i5-6400 4.38GHz @1.36v (162.2 BCLK) - Z170M-Plus - 2x8GB @3244C16- Biostar RX 570 8G w/ MSI Armor cooler
[BIOS] BCLK: 162.2 (x27) / Vcore 1.35 / DRAM 3244 (XMP timings) / FCLK 1GHz (1622) / RebarUEFI patched
ROG G531GT : i7-9750H (uv) - GTX 1650 +700mem - 16+8GB @2666 - 1920x1080@145Hz (up to 172Hz) IPS panel
[Throttlestop] FIVR - Vcore -160 / Vcache -105 / iGPU+unslice -125 (IccMax 255)
i5-4690K + Z97-AR + Panram Blue DDR3 2800 2x4GB Lightsaber Blue
iMac 21.5" (late 2011) : i5-2400S - Samsung 4x4GB PC3-1333 - HD 6750M 512MB - cheap Winten SSD (MacOS High Sierra) - 1920x1080@60 LCD
Acer Z5610 "Theatre" Core 2 Quad Q9550 - 2x2GB PC3-1333 (Samsung) - 1920x1080@60Hz Touch LCD - great internal speakers
https://linustechtips.com/topic/1600302-dumb-or-it-will-work/#findComment-16646473
7 hours ago, thekingofmonks said:
Any links?
Well, based on what I see in my Ikea Idasen, and a bunch of chinesium dual-motor sitstand desk irl :
2 Boxes, on each leg (This is the control box / system)
2 Motors, each connected to the box, either inside the legs, in the boxes, or exposed near the box
1 remote controller
Taking example from my Idasen.
- One of the box has the marking "Master" , it has 6 pin molex port (like GPU power port, just different key shape), a 2-pin molex header, and what looks to me an RJ45 port.
- The other box only has a 6-pin molex port.
- The two boxes are connected to each other through a male-to-male 6pin molex cable
- The power supply for the table connected to the 2pin port on the Master
- The remote controller is connected to the RJ45 port on the Master
Idasen Sitstand manual, quite detailed pictures, cabling section starts from page 13 :
https://manuals.plus/m/5d11691169cfee39aa87e4577b69db1e5ef244a3bc7e4555cf540f4f3fcb5162_optim.pdf
Here's another of Ikea's sitstand table, Mittzon, cabling section starts from page 13 :
https://www.ikea.com/nl/en/assembly_instructions/mittzon-underframe-sit-stand-for-desk-electric-white__AA-2421368-3-100.pdf
Different desk, but looks quite similar system to me
https://linustechtips.com/topic/1600302-dumb-or-it-will-work/#findComment-16646857
