If you don't want to replace your motherboard, a Meshroom D can fit your current board and is about as small as you can get assuming your ATX PSU and CPU cooler fit.
https://ssupd.co/products/cases-meshroom-d
If you need smaller, you need an ITX motherboard and SFX/SFX-L PSU.
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2 - Windows 11 Pro
https://linustechtips.com/topic/1597229-i-really-need-help/#findComment-16629480
