So recently i built a pc with an asus 1080ti poseidon and r5 3600, 16gb of ram and 750w of power and im really not sure what's happening, at first it was fine i could play games but after a week or less it all went downhill so fast, minecraft completely crashed and sent me an error about old drivers or a recording software interrupting the pc, but i rolled back my drivers, reinstalled new ones, tried all of that, deleted any recording software or benchmarking that has overlay yet nothing changed, now recently i can play a little again but the fps is horrendous, with my specs im only getting about ~48fps averages and 1% lows of 15-30fps, i only play mc with shaders and minimal graphic settings, on other games too like assassins creed i just crash or get REALLY bad performance, someone help!
https://linustechtips.com/topic/1597096-performance-way-less-than-should-be/
check the cpu temperature, if the numbers look normal then open up gpuz and look for any power/temperature throttling in the sensors tab, under PerfCap reason
gaming system: Intel core I9 12900ks / biostar Z690A valkyrie / 4x8gb corsair Vengeance @3333Mhz ram / RX 7900XTX pulse gpu / Thermalright peerless assassin 140 /Coolermaster Qube 500 case / Be Quiet Dark Power Pro 12 1500w power supply
laptop: Dell xps 9510, 3.5k OLED, i7 11800h, rtx 3050 ti, 2x16gb DDR4 @ 3200Mhz, 1TB main drive, 2TB add in ssd
Check temps in HWinfo64, CPU and GPU hotspot temps
current PC:
PC configs I used before:
