Ofc,it can't be compared to manual overclocking but i believe you have a problem here.
Try automatic overclocking wwith the oc genie and if it works,you are doing something wrong, If it doesn't,something is wrong with the mobo.
Exactly.
A water-cooled mid-tier gaming PC.
I don't get it. I'm doing everything that you are saying, but it's not working.
It would be nice if you gave a detailed description of what you are doing in your OC from start to finish.
Also check this video and see if you have been doing this.
Also check
Finally I got it working! I tried the first method from that video and I've got 4.2GHz OC with temperatures maxing out at 59C :)
Thank you!
Should I try going higher now?
Case: Silverstone TJ07 CPU: i5 3570K Motherboard: Asus Z77 Sabertooth RAM: Dominator Platinum 8GB GPU: SLI GTX 970 G1 Storage256GB Samsung 840 Pro + 3TB WD Green PSU: Corsair RM850 Monitor: Asus PB278Q Cooling: Water cooling with acrylic tubes HeadphonesPhilips Fidelio X2 DAC: Schiit Modi Amp: Schiit Vali
Thank you!
Why not just make sure you save the first OC to your profile list first.
Ok
Saved it and bumped it up to 4.3. Prime95 has been running for about 20mins
