i need help
Go to solution Solved by Kilrah,
Just now, prokapper said:
new build no os no changes
Press Y then, first time you put a CPU on a mobo the TPM needs to be initialized.
Context might help to know.
F@H
GPD Win 2
https://linustechtips.com/topic/1595201-i-need-help/#findComment-16615270
 What did you do or change, is an OS installed or not already, which one if so, or is this a new build...?
F@H
GPD Win 2
https://linustechtips.com/topic/1595201-i-need-help/#findComment-16615280
F@H
GPD Win 2
https://linustechtips.com/topic/1595201-i-need-help/#findComment-16615284
