timing differences between differnt cl30 kits important?
Solved by Hinjima,
13 minutes ago, MrSimSim said:looking at 6000mhz 64gb cl30 kits and the 2 im looking at are both cl30 but have a bit of difference in timing. 1 is 30-36-36-76 while being $25 more expensive and the other is 30-38-38-96. Whill there be a preformance difference and how big if so? I don't view $25 as a lot since I'll be going with a 5090 at release but liked the look of both of the kits and was intrested in if it actually matters. any help very appreciated
Maybe an fps or two difference.. if that.
So we are talking maybe 540fps vs 539 fps.
