NZXT C1500 Platinum ATX3.1 https://hwbusters.com/best_picks/best-atxv3-pcie5-ready-psus-picks-hardware-busters/7/ but like said above this is overkill.
54 minutes ago, Corrupt_Liberty said:
EVGA SuperNOVA 1600 T2
Launched in 2016 and EOL atm. Don't know why you don't recommand an ATX3.x unit.
https://linustechtips.com/topic/1594252-power-supply/#findComment-16609287
It's efficient, reliable and a known quantity for years.  He has no need for ATX 3.x.  But then, he also has no need for 1600 Watts.  The only reason for ATX 3.x is to deal with nvidia power spikes and their fire hazard 12VHPWR connector.
However, if you insist, I'd go with Seasonic Prime PX-1600
Malo Periculosam Libertatem Quam Quietum Servitium
https://linustechtips.com/topic/1594252-power-supply/#findComment-16609307
1 hour ago, Hypothermia said:
I had be quiet dark pro 13 1600w it lasted me like 3 months.... Soo better buy trusted brands i think
What's not trusted about NZXT? CWT is the OEM behind it and is one of the biggest and most trusted OEMs. They make very reliable and high end PSUs for Corsair, Adata/XPG, Asus, Deepcool, Montech, MSI, NZXT, Thermaltake and lots of others.
https://linustechtips.com/topic/1594252-power-supply/#findComment-16609546
I dont want digital if rly  because had huge problem with that digital dark pro 13 and costum cabels is big plus for me because of build
https://linustechtips.com/topic/1594252-power-supply/#findComment-16609695
I want smth with costum cabels already, soo tx 1600 noctua is good choise i think and its not digital i think
https://linustechtips.com/topic/1594252-power-supply/#findComment-16609696
Most powerfull power suplys 12 v rails is controled digital, not analog like older ones, and i had digital one it was bad choise it lasted 2 weeks at first was replaced and affter died again in 2 months. It was dark power pro 13 1600 w. Never again digital one
https://linustechtips.com/topic/1594252-power-supply/#findComment-16609743
