Budget (including currency): 2300usd
Country: United States
Games, programs or workloads that it will be used for: Gaming all sorts
I want to do a 4070 ti super build and I need ideas on how much ram I should use what motherboard and such please halp
https://linustechtips.com/topic/1593644-i-need-help/
PCPartPicker Part List
CPU: *AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor  ($359.00 @ Amazon)
CPU Cooler: *Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  ($37.90 @ Amazon)
Motherboard: *MSI MAG B650 TOMAHAWK WIFI ATX AM5 Motherboard  ($179.99 @ MSI)
Memory: *TEAMGROUP T-Create Expert 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($87.99 @ Amazon)
Storage: *Silicon Power UD90 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($89.97 @ B&H)
Video Card: *Asus PRIME OC GeForce RTX 4070 Ti SUPER 16 GB Video Card  ($799.99 @ Amazon)
Case: *Montech AIR 903 MAX ATX Mid Tower Case  ($74.98 @ Amazon)
Power Supply: *Thermaltake Toughpower GF3 TT Premium 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($89.99 @ Amazon)
Operating System: *Microsoft Windows 11 Home OEM - DVD 64-bit  ($119.99 @ Amazon)
Monitor: *MSI G272QPF E2 27.0" 2560 x 1440 180 Hz Monitor  ($174.99 @ MSI)
Total: $2014.79
Generated by PCPartPicker 2024-12-24 20:30 EST-0500
https://linustechtips.com/topic/1593644-i-need-help/#findComment-16605497
when did the 7800x3D's price fix? wow
CPU: AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor  ($359.00 @ Amazon)
CPU Cooler: *Thermalright Peerless Assassin 120 SE 66.17 CFM CPU Cooler  ($34.90 @ Amazon)
Motherboard: *MSI B650 GAMING PLUS WIFI ATX AM5 Motherboard  ($149.99 @ MSI)
Memory: *Silicon Power XPOWER Zenith Gaming 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($79.97 @ B&H)
Storage: *SK Hynix Platinum P41 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($124.99 @ Newegg Sellers)
Case: *Phanteks XT PRO ULTRA ATX Mid Tower Case  ($74.98 @ Newegg)
Total: $1713.81
Generated by PCPartPicker 2024-12-24 20:43 EST-0500
current PC:
PC configs I used before:
https://linustechtips.com/topic/1593644-i-need-help/#findComment-16605502
13 minutes ago, Why_Me said:
Budget SSD for 2000$ PC?
current PC:
https://linustechtips.com/topic/1593644-i-need-help/#findComment-16605503
59 minutes ago, Corrupt_Liberty said:
I think the OP would be better off with a better SSD myself.  You shouldn't have to cheap out at this budget.
The only advantage the SK Hynix SSD that @podkall linked is DRAM cache. The Silicon Power SSD uses a SLC controller to buffer the cache just like the WD SN770.
https://linustechtips.com/topic/1593644-i-need-help/#findComment-16605562
UD90's SLC cache isn't covering lot of area and the fuller the drive is the less cache you have
current PC:
https://linustechtips.com/topic/1593644-i-need-help/#findComment-16605726
