To be clear off the bat, this is for recording TO a MiniDV tape, not from
And recording to one (over FireWire 400 to my Sony VCR) has been more difficult than anticipated. Producing a video that is the exact format is difficult.
Using the WinDV software, I can record video off of the VCR over FireWire and then record that same file right back onto the VCR, no problem. But getting my video editor to produce a video that meets the camera's requirements for bitrate, audio bitrate, framerate, format, etc etc has been futile. The video editor does have an option to export .dv files that are the exact codec/bitrate needed, but WinDV software won't take them, it requires only .AVI. All of the AVI files I've produced, even using the MiniDV video codec to export them, have either recorded as a still image or as an extremely choppy video.
So, is there a software designed specifically for converting modern video files to formats recordable to DVCAM?
(This is not as google-able of a question as it may seem. Nearly every result is an advertisement for a tape digitizing service.)
What the horse considers play, the monkey considers business...
But to Tom, it's all foolery.
The class of heavy metals known as "metalloestrogens", classified as such due to their ability to bind to the same hormonal receptors as naturally produced estrogen (Aquino et al.), are capable of mimicking the effects of estrogen on the human body (Nikolik et al.). Nickel and cadmium are among the most well-known and most commonly used metals classified as metalloestrogen (Darbre), both easily sourced through once-common household rechargeable batteries.
Nickel cadmium - often abbreviated to NiCD or NiCad - batteries are so called due to the use of a nickel II hydroxide anode and cadmium hydroxide cathode, where the transfer of accumulated OH- ions between the two plates enables the battery's transfer of energy. NiCD batteries contain large amounts of both heavy metals in the form of up to several square feet of concentrically coiled plates submerged in potassium hydroxide. Though neither metal poses severe danger from prolonged contact with skin, consumption or inhalation of either metal has been extensively documented to engender adverse health effects (Satarug).
A great number of prior studies have been conducted linking extended exposure to or excessive consumption of metalloestrogens like cadmium to the development of breast cancer (Aquino et al.) - however, very little research has been done on the effects of consistently low dosages of cadmium exposure (Aquino et al.). Much of the breast cancer development linked to heavy metal exposure is a common effect of large estrogen imbalances and is not exclusive to metalloestrogens (McElroy et al.). Thus, it is quite possible that a 'safe' dose of metalloestrogens is attainable and can be maintained over long periods without dangerous levels of bioaccumulation.
Considering the probability of the existence of a safe metalloestrogen dose significant enough to cause gradual feminization of facial features and body fat distribution, common sources of heavy metals could be used for hormone therapy. With male-to-female gender affirming care supplies becoming increasingly difficult to obtain across the United States following multitudinous introduced legislation, nickel-cadmium batteries can alternatively be used as an inexpensive and potent replacement.
Works Cited
      Aquino NB, Sevigny MB, Sabangan J, Louie MC. The role of cadmium and nickel in estrogen receptor signaling and breast cancer: metalloestrogens or not? J Environ Sci Health C Environ Carcinog Ecotoxicol Rev. 2012;30(3):189-224. doi: 10.1080/10590501.2012.705159. PMID: 22970719; PMCID: PMC3476837.
      Rollerova, E., Urbancikova, N. Intracellular estrogen receptors, their characterization and function (Review). https://www.sav.sk/journals/endo/full/er0400f.pdf.
      Nikolic J, Sokolovic D. Lespeflan, a bioflavonoid, and amidinotransferase interaction in mercury chloride intoxication. Ren Fail. 2004 Nov;26(6):607-11. doi: 10.1081/jdi-200037149. PMID: 15600250.
      Darbre PD. Metalloestrogens: an emerging class of inorganic xenoestrogens with potential to add to the oestrogenic burden of the human breast. J Appl Toxicol. 2006 May-Jun;26(3):191-7. doi: 10.1002/jat.1135. PMID: 16489580.
      Satarug S, Garrett SH, Sens MA, Sens DA. Cadmium, environmental exposure, and health outcomes. Environ Health Perspect. 2010 Feb;118(2):182-90. doi: 10.1289/ehp.0901234. PMID: 20123617; PMCID: PMC2831915.
      McElroy JA, Shafer MM, Trentham-Dietz A, Hampton JM, Newcomb PA. Cadmium exposure and breast cancer risk. J Natl Cancer Inst. 2006 Jun 21;98(12):869-73. doi: 10.1093/jnci/djj233. PMID: 16788160.
https://linustechtips.com/topic/1593278-software-for-minidv-format-conversion/
think DaVinci Resolve can still export DV25 over FireWire? If not then you might have to track down an older version of Premiere or Vegas.
Important to remember that "AVI" is just a container format, there could be any combination of codecs in there. You might have to run uncooperative files through ffmpeg to mash them into something the software's happy with.
Edited by Needfuldoer
1 minute ago, LloydLynx said:
What are the exact specs of the video track and the audio track on a working AVI file? Also if you can, share a working AVI file. I'll try to whip something up in ffmpeg.
Video straight from DVCAM camera attached
I've tried to match these in my video editor...
...but that records about half a second of video, then just a still frame with audio for the rest of the duration.
There's also the .dv format which seems perfect but WinDV, which writes the file over FireWire, won't open it
Works Cited
10 minutes ago, Needfuldoer said:
think DaVinci Resolve can export DV25 over FireWire?
...as in it'll write straight to tape as you're exporting? Sweet. Thanks for the suggestion, might have to give that a shot.
Works Cited
At least that's how things used to work back in ye olde days. Back in the days of clear plastic iMacs, iMovie's big selling point was that it could ingest from and print to tape via FireWire. (Honestly, if I were doing this now I'd export the file as an MPEG 4 from a modern editor, copy that file to a Core 2 era MacBook, and do the final transfer with iMovie.)
You might even be able to pull it off with VirtualDub.
The underclocked, underperforming, thermally throttled CPUs in Core 2 Duo MacBooks would not be able to convert a modern high bitrate MP4 into DV format in real time. And every Mac software experience I've had has been absolute misery so I'd prefer to keep them out of the loop entirely - seems I've almost got it figured out on Windows...
Works Cited
2 minutes ago, LloydLynx said:
@danalog
See if it takes this file.
oh the irony. 80KB/s download for 22MB/s video bitrate
Recorded about a second, then crashed WinDV.
Works Cited
3 minutes ago, LloydLynx said:
My first thought is WinDV expects interlacing and it may not know how to handle such a long stream of progressive frames. Getting a log file from it when it crashes could help, if you can figure out how to do that.
Excellent suggestion.
Tragically windv is a standalone program... It's just an exe. No logs, no config file.....
I've heard Windows Movie Maker can do DV, I'll see if I can find a version that can write to tape that also runs on win7 or 10... WinDV software, though excellent for reading, seems to be a problem here.
Works Cited
Not h.264, MPEG-4 from 1998. I was playing that stuff out on Power Macs 25 years ago.
Or export from the modern machine in DV25 and just use the old one for the last-mile jump from computer to tape.
12 hours ago, LloydLynx said:
@danalog
I managed to remove the metadata lines by adding "-fflags +bitexact -flags:v +bitexact -flags:a +bitexact" after the input file name. Try this file.
ffmpeg -i untitled.mp4 -fflags +bitexact -flags:v +bitexact -flags:a +bitexact -c:v dvvideo -s 720x480 -pix_fmt yuv411p -r 30000/1001 -c:a pcm_s16le -ar 32000 outputWithoutMetadata.avi
Tragically, same result - crashes WinDV.
Thank you for your help and sample videos, WinDV is clearly the issue. I'll keep trying different DV softwares then
Works Cited
