Help with building NAS
Go to solution Solved by Bersella AI,
This setup is sufficient enough. My server has a dual-core Pentium G4600 processor, and has been hosting a dozen of services for years.
TrueNAS Scale and HexOS come with native support for Docker. There should be an official Tailscale image in the Apps section, and only a few parameters (including an auth key) need to be filled. The Docker Hub webpage may be referred to for more details.馃槂
I've decided to build a NAS for storing photos, videos, and other files. I already have 4x 2TB HDDs, which I think will be sufficient for now. I'm considering using Hex OS, as I鈥檝e tried TrueNAS before but I'm also intrigued by Hex OS.
I haven't decided which system to use yet; I have an i5 6500T along with a MOBO and 8GB of RAM. Is this system adequate for a NAS build?聽
Additionally, if I choose to use TrueNAS, I would like to know how to set it up so I can access it from anywhere, such as Tailscale.
Can anyone guide me through this?聽
https://linustechtips.com/topic/1593259-help-with-building-nas/
<-- Moved to Servers, NAS, and Home Lab -->
Community Standards
Please make sure to Quote me or @聽me to see your reply!
Just because I am a Moderator does not mean I am always right. Please fact check me and verify my answer.聽
"Beast Mode"
Dedicated Streaming聽Rig
聽Ryzen 7 3700x | Asus B450-F Strix聽| 32gb Gskill Flare X 3200mhz | Corsair RM550x PSU | MSI Ventus 3060 12gb | 250gb 860 Evo m.2
Phanteks P300A |聽聽Elgato HD60 Pro | Avermedia Live Gamer Duo | Avermedia 4k GC573 Capture Card
https://linustechtips.com/topic/1593259-help-with-building-nas/#findComment-16602880
https://linustechtips.com/topic/1593259-help-with-building-nas/#findComment-16603109
