Hello, I have assembled the following PC
MoBo ASUS TUF GAMING X670E-PLUS,
RAM G.Skill Flare X5 DDR5 64GB (2x16) 6000MHz CL36,
CPU Ryzen 7 7700X 4,5GHz +Cooler be quiet! Dark Rock Pro 4 135mm
PSU Be Quiet Pure Power 12M 750W
I had a lot of problems using 4 rRAM modules until the CPU died and was replaced in RMA
Installed the new CPU with only 2 ram modules I had other problems:
Using bios defaults my pc gives BSOD at the windows login screen
My RAM F5-6000J3636F16GX2-FX5 is certified by asus for my mobo
anyway I was checking what was the problem and I installed 1 single module
and did a memtest86 from usb stick and had a lot of error.
What can be wrong?
How to Solve it?
Manufacturer ASUSTeK COMPUTER INC.
Product Name TUF GAMING X670E-PLUS
Version Rev 1.xx
CPU Type AMD Ryzen 7 7700X 8-Core
CPU Clock 4493 MHz [Turbo: 5490.7 MHz]
# Logical Processors 16 (8 enabled for testing)
L1 Cache 16 x 64K (311388 MB/s)
L2 Cache 16 x 1024K (129000 MB/s)
L3 Cache 1 x 32768K (70411 MB/s)
Memory 15602M (30800 MB/s)
RAM Configuration DDR5 4800MT/s / x1 Channel / 40-40-40-77 / 1.100V
Number of RAM SPDs detected 1
SPD #0 16GB DDR5 EXPO 1Rx8 PC5-48000
Vendor Part Info G Skill Intl / F5-6000J3636F16G / 09507DFD
JEDEC Profile 4800MT/s 40-40-40-77 1.1V
EXPO Profile 1 6000MT/s 36-36-36-96 1.35V
Number of RAM slots 4
Number of RAM modules 1
DIMM A1 Empty slot
DIMM A2 16GB DDR5 1Rx8 PC5-38400
SMBIOS Profile 4800MT/s 1.1V
DIMM B1 Empty slot
DIMM B2 Empty slot
Result summary
Test Start Time 2024-12-19 10:32:04
Elapsed Time 2:16:56
Memory Range Tested 0x0 - 10000000000 (1048576MB)
CPU Selection Mode Parallel (All CPUs)
CPU Temperature Min/Max/Ave 39C/95C/64C
Lowest memory speed 4800 MT/s (40-40-40-77)
Highest memory speed 4800 MT/s (40-40-40-77)
# Tests Completed 48/48 (100%)
# Tests Passed 26/48 (54%)
Lowest Error Address 0xDAE960 (13MB)
Highest Error Address 0x4DB6EC7C (1243MB)
Bits in Error Mask 0000000008000000
Bits in Error 1
Max Contiguous Errors 2
CPUs that detected memory errors { 0, 2, 4, 6, 8, 10, 12, 14 }
Bits in Error
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . x . . . . . . . . . . . . . . . . . . . . . . . . . . .
63        0
Test # Tests Passed Errors
Test 0 [Address test, walking ones, 1 CPU] 4/4 (100%) 0
Test 1 [Address test, own address, 1 CPU] 4/4 (100%) 0
Test 2 [Address test, own address] 4/4 (100%) 0
Test 3 [Moving inversions, ones & zeroes] 2/4 (50%) 8
Test 4 [Moving inversions, 8-bit pattern] 0/4 (0%) 92
Test 5 [Moving inversions, random pattern] 0/4 (0%) 88
Test 6 [Block move, 64-byte blocks] 4/4 (100%) 0
Test 7 [Moving inversions, 32-bit pattern] 0/4 (0%) 264
Test 8 [Random number sequence] 0/4 (0%) 96
Test 9 [Modulo 20, random pattern] 0/4 (0%) 37
Test 10 [Bit fade test, 2 patterns, 1 CPU] 4/4 (100%) 0
Test 13 [Hammer test] 4/4 (100%) 0
https://linustechtips.com/topic/1592990-problem-with-my-pc-config/
3 minutes ago, KukKaBubBa said:
*snip*
Sounds like you either got bad RAM that needs to be replaced, or a bad RAM slot. Try testing the other RAM sticks individually and see if you are still getting errors
MAIN PC:
CPU: AMD Ryzen™ 7 7800X3D Motherboard: Gigabyte B650 Eagle AX CPU Cooler: EVGA CLC 240 GPU: EVGA RTX 3080 FTW3 Ultra RAM: TEAMGROUP Expert T-Create 32GB (2x16GB) 6000Mhz CL30
Case: CoolerMaster TD500 Mesh PSU: Thermaltake GF1 PE 750w Storage: 1TB Western Digital Blue 3D + 1TB Crucial P1 + 1TB ADATA XPG Gammix S11 Pro + 4TB Seagate Barracuda 5400RPM OS: Windows 10 Home
Headphones: Philips SHP9500s   Keyboard: Corsair K70 RGB MK.2 Cherry MX Red Displays: Gigabyte M27Q (27" 1440p 170hz IPS), Samsung UN32EH4003FXZA (32" 768p 60hz TV)
Former parts that I've used:  Intel® Core™ i3-9100F, Intel® Core™ i9-9900k, Asus Dual OC 2080, Gigabyte Aorus Master 3080, Gigabyte Gaming OC 3080, EVGA XC3 Ultra 3080, EVGA FTW3 Ultra 3080 Ti, EVGA 3060 XC, ASRock Z390 Phantom Gaming 4-CB, Gigabyte Z390 Aorus Pro Wifi, ADATA XPG 16GB (2x8GB) 2400Mhz CL16, Corsair Vengeance 32GB (4x8GB) 3000Mhz CL15, Scythe Fuma 2, Acer XG270HU.
10 minutes ago, KukKaBubBa said:
RAM G.Skill Flare X5 DDR5 64GB (4x16) 6000MHz CL36,
You'll want to test each stick and each slot individually to confirm it's not one of the sticks or slots that is bad.
DDR5 has been well known from the start to not work well in quad configuration. It is highly recommended to only use 2x**GB kits of ram in DDR5 systems. Also to never mix and match kits, even if they are the same make and model, regardless they are not guaranteed from the factory to work together.
How is this ram divided? Did you purchase a single kit of 4x16GB, two 2x16GB kits, or four single 16GB module kits? I'm guessing it was two 2x16GB kits you paired together to make a quad kit?
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
Wow, thanks a lot for your reply.
(RAM was from 2 kits 2x16GB, after the first major problem I read online that mixing kits "was bad" so I sold 1 kit and kept only 2x16GB kit)
to proceed with testing is it better to first test the same stick in different slot or to test another stick in the same slot?
Can we exclude that the problem is once again the CPU o the CPU settings?
Start with testing another stick in the same slot, to see if it's a slot problem. If you get no errors, it's the other stick that's bad and needs replaced. If you still get errors, try testing another slot. If you get no errors in another slot, that means the one slot is the issue and the motherboard needs to be RMA'd.
And if you get errors no matter what you do, I'm out of ideas 😂
MAIN PC:
No. If there is an issue with a contact between the CPU and socket, it would result in issues with a slot. You would be unlikely to POST if that were the case though.
Ok, so you read about the mixing kits thing and sold one. Did you make sure you kept the kits paired together properly? The modules that pair together will have sequential serial numbers. If you accidentally mixed the kits up and the kit you have has two modules with non-sequential serial numbers that could be the issue, even though you got rid of one of the kits, you'd still be mixing modules.
As for testing the slots and ram, I typically will test the modules first, if both modules work in the first slot on the board with no errors, I then use one of the modules to test each slot, if neither module had errors by themselves and they post in each slot it usually rules out the ram modules or the slots being bad. If it starts crashing once both sticks are paired together it's an issue with the modules working together and most likely means you didn't keep the paired kits together.
Having a light OCD I noted serials of each RAM kit in order to keep them together with their own plastic blister, so yes every module is paired with his default twin.
The second module is performing a good test it is about to finish pass 3 without errors so the first module was surely faulty.
Is it mandatory to do 4 passes with memetest86 so repeating the schedule from "test 0" to "test 13" four times or it would be enough to do 1 single pass?
Usually 1 single pass is enough. If the modules are bad they typically show errors pretty early on.
I once had a stick that only failed on the 2nd pass, so I'd say do at least 2 passes.
Ok, so I got another kit of QVL RAM from my friends
and also those modules works fine in the slot 2-4 following MoBo manuals requirements.
Then I tried to mount the RAM kit on the black slots (1 and 3)to test laso those slots of the MoBo but the PC doesn't post and the yellow RAM LED stays on.
So I tried to use 1 single RAM module to test all the slots but my MoBo posts only if the Ram i installed on slot 2 or 4
if I test slot 1 or 3 the pc won't post
MoBo manual suggest to use following layouts:
1 single ram module : slot 2
2 ram modules: slot 2 and 4
4 ram modules: fill every slot (of course)
is it normal that inserting a single stick of ram in slot 1 or in slot 3 the system fails to post?
same thing happens inserting 2 sticks in slot1 and slot 3.
is there a way to cross check if MoBo has a damage on those 2 slots?
Fairly normal. I don't really have any feeling on how common it is in terms of a percentage, but it's certainly not uncommon.
I do not get it...
Are those slot faulty or is a common behaviour of how a MoBo works?
I see many user telling me on this and other forum to test every MoBo slot with 1 single stick of RAM
but how am I supposed to do that if the mobo is built up to post with 1 single stick of ram only if it is installed on slot 2 or 4?
You can't on those boards. RAM slots are very rarely faulty though.
Some motherboards just don't like it.
Maybe I understood...
I ran the following tests:
1 stick in A2 = OK post, ok memtest86
1 stick in B2 = Ok post, ok memtest86
1 stick in A2 and 1 stick in B2 = ok post, ok memtest86
1 stick in A1 = No post, yellow LED on steady
1 stick in B1 = No post, yellow LED on steady
1 Stick in A1 and 1 Stick in B1 = No post, yellow LED on steady
1 Stick in A1 and 1 Stick in A2 = Ok post, memory at 3600MT/s single channel, memtest ok
now I'll try to do a test with A2 and B1
but it seems to me that if you don't put at least 1 stick in the gray slots the mobo (A2 or B2)system will not post!
am I right?
