Quick CPU cooler question
Go to solution Solved by RONOTHAN##,
Yeah, it's fine as that chip doesn't draw much power. The only downside is that it's a bit loud.
Worst case scenario, you run it for a few weeks then upgrade to a real cooler if you decide the noise is too much for you. It is free after all.
