6 minutes ago, Psittac said:
Quick question, my motherboard has a eight pin and a four pin but the power supply only has two 8-pin cables. Can I plug in 1 8 to the eight pin? And can I also plug in an 8 pin to the four pin?
MB is gigabyte x870 eagle Wi-Fi 7
PSU is MSI mag a1000g pcie5
1x8pin will be enough unless you run a 7950X or 9950X at 100% load.
1x8pin can supply a continous load of 226w.
But yes. You can plug the 8 pin into the 4 pin and leave the half outside.
Not ideal of course.
https://linustechtips.com/topic/1592145-cpu-power/#findComment-16595525
There is a little evidence to support the lower resistance to the load gives more predictable voltages, and slightly better clocks(under PBO)
If someone has helped you out on the forum don't forget to give them a reaction to say thank you!
The only true wisdom is in knowing you know nothing. - Socrates
Please put as much effort into your question as you expect me to put into answering it.
https://linustechtips.com/topic/1592145-cpu-power/#findComment-16595529
2 minutes ago, Psittac said:
Turns out both of the 8-pin's could be split in half
yeah, that's standard
https://linustechtips.com/topic/1592145-cpu-power/#findComment-16595563
