Cooling fans
Solved by Hinjima,
22 minutes ago, ReapersFury said:Hey guys
I need a bit help here, my aio cooler works just fine, but the noise level is just too much, so I bought 2 Noctua fans and take out the fans that came with the aio and change them to Noctua fans instead.
will that work?
and the aio connects with a hub and on the backside of my case have a hub too, should I connect the new fans to the hub on the backside or the motherboard.
The AIO's fans are quite good in terms of cooling and noise levels.
Did you try to adjust the fan curve for the fans? Was it still too noisy?
But yes, you should be able to swap them out
