Budget (including currency): €250
Country: Ireland/UK
Games, programs or workloads that it will be used for:
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at,
etc):
Need a DDR4 motherboard that works fine with PCIE 4.0 SSD and a ryzen 5600X. Any Irish or UK site and need as quick as possible. Thanks in advance!
https://linustechtips.com/topic/1590958-need-a-motherboard/
Country: Ireland/UK
etc):
What's the format? ATX?
https://linustechtips.com/topic/1590958-need-a-motherboard/#findComment-16586800
https://uk.pcpartpicker.com/list/yNnTfv
its ddr4 so it will work with your ram. but if you just want a good motherboard for am4, Gigabyte B550 GAMING X V2 ATX AM4 Motherboard (B550 GAMING X V2) - PCPartPicker
i doubt OP has a proprietary form factor so why ask? atx has been the standard for over 2 decades so its probably that. why ask?
https://linustechtips.com/topic/1590958-need-a-motherboard/#findComment-16586801
What if his case is a microatx? 🤷‍♂️
https://linustechtips.com/topic/1590958-need-a-motherboard/#findComment-16586809
Accidentally posted this question twice it seems. So my apologies. But I think I’m gonna go with a used Gigabyte B550 AORUS ELITE AX V2 ATX AM4 Motherboard. My case is an ATX case. So that should be okay. And pcie4 ssd would be okay with that too? Also what’s ppls experience with buying used boards?
https://linustechtips.com/topic/1590958-need-a-motherboard/#findComment-16586816
As long as VRM's are okay, all slots work, and nothing is damaged or bent, should be fine.
On 12/1/2024 at 12:09 PM, C2fashy said:
Would that be this https://amzn.eu/d/9R0T4qp and if so. I don’t think it’s WiFi? U have one that would be WiFi?
MSI MAG B550 TOMAHAWK MAX WIFI
https://linustechtips.com/topic/1590958-need-a-motherboard/#findComment-16587878
