Hey, i was wondering if there's anything i can do to fully optimize my pc for gaming while using windows 11聽
i dont know what to do exactly as im new to this pc building and optimizing 馃檪
thank you in advance 馃槃
Specs:
Motherboard: X570 AORUS PRO WiFi
CPU: Ryzen 5600x
Ram: 64gb ddr4 3200mt/s
GPU: ASUS Dual GeForce RTX 3070
i play on 1440p
https://linustechtips.com/topic/1590955-optimization-help/
Install the nvidia app so you can get newest drivers, update bios frequently, don鈥檛 use Google chrome (I like opera gx but it isn鈥檛 for everyone.) there are more but they aren鈥檛 coming to mind.
I try to be a human, but I cannot, because I have returned to monke.
Hehe boi
POV- when it can run crysis-
聽( 蜐掳 蜏蕱汀掳)
https://linustechtips.com/topic/1590955-optimization-help/#findComment-16586805
Go to Windows settings and run through Apps and Privacy and similar tabs, and uncheck anything you feel like you won't need.
Check if XMP/DOCP is on, if RAM is running at 3200Mhz.
current PC:
PC configs I used before:
https://linustechtips.com/topic/1590955-optimization-help/#findComment-16586837
thank you i will try opera gx, anything else maybe? 馃槃
https://linustechtips.com/topic/1590955-optimization-help/#findComment-16586861
thank you for responding and yes the ram is running at 3200mhz
https://linustechtips.com/topic/1590955-optimization-help/#findComment-16586863
There are the more basic optimization things to do, like being sure there aren't a ton of apps running full time in your task tray, keeping the recycle bin emptied fairy regularly, making sure your new Windows install turned on the high refresh of your monitor in the display settings as it used to miss it sometimes. Just enjoy the new PC and don't worry too much about getting the highest fps, focus on getting a consistent fps, and that it's in the VRR target range for your display.聽
Good Luck and enjoy the new rig!
https://linustechtips.com/topic/1590955-optimization-help/#findComment-16592800
