39 minutes ago, johnsn said:
RTX 2060 Super
AMD Ryzen 3600 12 Thread Processor
MSI MAG B550 TOMAHAWK
16 GB Ram
did you change something (hardware/software) or did the PC suddenly started doing this?
or is it new and always does this?
current PC:
PC configs I used before:
https://linustechtips.com/topic/1590864-need-help-with-my-pc/#findComment-16586187
Suddenly started doing this, only thing i've done was add more SSD 2 weeks ago, this started yesterday
- My BIOS Version is American Megatrends International, LLC. A.B0, 8/25/2022
- Specifically crashes when running GTA (Been playing it for couple weeks now, just started yesterday)
https://linustechtips.com/topic/1590864-need-help-with-my-pc/#findComment-16586206
OS on same drive?
Temps? What SSD?
current PC:
https://linustechtips.com/topic/1590864-need-help-with-my-pc/#findComment-16586214
1 minute ago, podkall said:
OS on same drive?
Temps? What SSD?
What do you mean OS on same drive? Sorry, I'm not too good with PCs, and for the SSD, I got https://www.amazon.com/dp/B0B9Y3DB2K?tag=pcpapi-20&linkCode=ogi&th=1 , someone here recommended me it
https://linustechtips.com/topic/1590864-need-help-with-my-pc/#findComment-16586215
which drive you got Windows on? Did you change it to this SSD or do you use the new SSD only for files?
current PC:
https://linustechtips.com/topic/1590864-need-help-with-my-pc/#findComment-16586292
