Hello
Currently i am planing a build and already have an xfx tripple fan  rx 5700xt it is 305 mm withouth the metal bracket and 326mm with. I am planong on getting deepcool ch 160 and maximum gpu length that i found is 305. Altho some forrums say it is 310. And i wanna know will it fit in there or do i have to buy a new gpu?
Good to know!👍
https://linustechtips.com/topic/1590490-will-it-fit/
23 minutes ago, KECO said:
Hello
If https://www.xfxforce.com/gpus/xfx-amd-radeon-tm-rx-5700-xt-td-8gb-gddr6 is the GPU you are asking about, its length is listed as 326mm. That is the length that should be used when checking case limitations.
https://linustechtips.com/topic/1590490-will-it-fit/#findComment-16583875
current PC:
PC configs I used before:
https://linustechtips.com/topic/1590490-will-it-fit/#findComment-16583922
